The code P1537 applies to two types of air intake manifold control systems:
(1) Intake Manifold Runner Control (IMRC)
(2) Intake Manifold Swirl Control (IMSC)
Both of these systems use similar components to essentially take the incoming air and distribute it among the cylinders in a certain way at a certain time. Since the systems and components are so similar, they share trouble codes.
Here is a post on the IMRC that sheds some light on the P1537 code:
Your '01 2.3L uses the IMSC system, which is described in more detail here:
Intake Manifold Swirl Control (IMSC) Vacuum Actuated System
The Intake Manifold Swirl Control (IMSC) Vacuum Actuated system consists of a manifold mounted vacuum actuator and a PCM controlled electric solenoid. The linkage from the actuator attaches to the manifold butterfly plate lever. The IMSC actuator and manifold are composite/plastic with a single intake air passage for each cylinder. The passage has a butterfly valve plate that blocks 60% of the opening when actuated, leaving the top of the passage open to generate turbulence. The housing uses a return spring to hold the butterfly valve plates open. The vacuum actuator houses an internal monitor circuit to provide feedback to the PCM indicating butterfly valve plate position.
Below approximately 3000 rpm, the vacuum solenoid will be energized. This will allow manifold vacuum to be applied and the butterfly valve plates to remain closed. Above approximately 3000 rpm, the vacuum solenoid will be de-energized. This will allow vacuum to vent from the actuator and the butterfly valve plates to open.
The swirl control actuator is located on the back of the intake manifold, along with the swirl control monitor electrical connector.
Weird the smog sheet has a diffrent explanation for the code, I do see that all the stuff on the internet has the same listing you use. The guy right before me failed with the same code. So it must be a common problem, is there a common fix?
No, it's not that common of a problem. And to have someone right in front of you fail with the same code seems like more than just a coincidence to me. What kind of vehicle/motor did that person have? Was it a Ford? I wonder if the engine even had an IMRC/IMSC system on it like yours does.
The description you have been given for code P1537 on the printout sheet is incorrect. Instead, the description matches up almost exactly with P0125, and so I'm wondering if that's really the problem. Is there any way for you to clarify this with the smog patrol people?
BTW, was your check engine light one when they smog-tested your truck?
The vehicle in front of me was a ranger but I don't know what engine it had, or what year.
yes the check engine light was on, when I reset it by disconnecting the battery it does not come back untill you turn it off and start it again. I was hopeing they would not turn it off and start it again. Most times they don't I sure miss my old smog guy.
I did order a code reader, I think I will wait and see what it comes up with.
If it's stuck open, it means you don't have a signal from the computer to the solenoid to apply vacuum to the system, so maybe the computer isn't getting the proper feedback from the vacuum actuator's internal sensor about it's real position, or the vacuum is being applied, but the system has a leak & is too weak to overcome the return spring, or maybe it's internal control arm is broken, or has become detached.
So, it seems to me you need to do some visual inspection, for mechanical problems & leaking vacuum connections & lnes & maybe some vacuum & electrical testing of the system & figure out why it's not responding to it's computers signal to close, if it's getting that signal.
Good post pawpaw and I agree with your suggestions. And just to clarify for the others - the springs are there to keep the butterfly plates open at no vacuum (>3000 rpm). Which means the solenoid must always be energized below 3000 rpm so as to allow vacuum to the actuator to keep the plates closed.
I have to think that both the vacuum and the electrical components of the IMSC system work the same way as the IMRC on my SHO's engine.
Well Rockledges nice post about how the system works, sure made thinking the troubleshoot through, much simpler didn't it.
Good find fix & fedback Gary, sounds like your probably about ready to pass that smog test. Just be sure to erase the code with your scanner, or pull the computers fuse, or disconnect the battery, long enough to erase the code, then drive it through the right driving sequece long enough, for the computer to reset all it's IM registers, so it's ready for emissions testing.
It took me a little while to understand it myself.
FWIW, the reason why the IMRC/IMSC systems work the way they do (i.e., the springs keeping the plates open a high rpms, vacuum keeping the plates closed at low rpms) is because at the higher rpms (WOT in most cases) engine manifold vacuum decreases to near zero.
