F250 stops
Old May 21, 2007 | 07:13 AM
Ravery's Avatar
Ravery
Smile Finally
I disconnected the MAP sensor and it shut off. I pulled the starter and had it tested; it failed bought new one and installed it and she started right up. When they break they really break. I replaced the CPS, starter solenoid, alternator, and the starter. Now all I have to deal with is that ABS light coming on. I guess I have to tke it to someone. This is going to kill me. Thanks for your help. This site really helped me alot.
FYI : Starter 13mm and 15mm
Alternator 13mm and 10mm
CPS 10mm
Starter solenoid 10mm and 6mm(not sure)
2002 F250 7.3l turbo diesel
Old May 21, 2007 | 08:07 AM
Ravery's Avatar
Ravery
Red face Spoke to soon
Looks like the automotive gods are laughing at me. I started and turned it off about 5 times yesterday no problem. Today I turned it off pulled the key out and engine still running. I was wrong about the MAP sensor I had to remove the negative terminals from both batteries to get it to turn off. Guess I will try to switch out the ignition. The saga continues.
Whiskey Tango Foxtrot?
Old May 21, 2007 | 08:19 AM
cangim's Avatar
cangim
Does your speedo still move when traveling? Seems a lot of time when the abs light is on it is because of the speeds sensor on the rear diff has gone out.
Old May 21, 2007 | 08:51 AM
Ravery's Avatar
Ravery
Abs
I took it for a spin and the first time I pressed the brake the light went off. Hopefully it just was on after reconnecting the batteries? Now if I can get the truck to turn off.
Old May 21, 2007 | 01:28 PM
blackhat620's Avatar
blackhat620
Ravery,
With a diesel the only thing that shuts off when you turn the key to off is the fuel system, since there is no spark plugs like on a gas engine.
So either the ignition switch is bad or on of the relays controlling the fuel system is sticking closed and needs to be replaced.
Hope this helps
Old May 21, 2007 | 05:29 PM
Ravery's Avatar
Ravery
Angry Killed
I changed the ignition switch and it turned off 3 different times and I thought I had it beat. But the next time I went to turn it off it would not. I had it; so I headed to the dealer and then it died again. This time it would not start. I had it towed to them. All I told them is that it died. I want to see what they say I need before I tell them what I changed.Thanks for all the help. I hate having to take it to them.
irishgot8
Jan 12, 2014 10:21 AM
afran
Feb 16, 2013 06:56 PM
chop33
Jan 6, 2011 09:57 PM
Old Time Ford
Sep 2, 2010 08:25 PM
91dirtydiesel
17
Jul 30, 2009 02:54 PM
