Power Loss
Old Aug 31, 2010 | 06:19 PM
Old Time Ford's Avatar
Old Time Ford
Power Loss
I've got a 84 F250 351w with a 2 bbl carb.and a 4speed. I had a bunch of problems all at once got most fixed except 1.When I take the truck up the road starting in 2nd I get 20mph and lose power shift to 3rd and power is back till I hit 30mph and lose it again then shift to 4th and have power until 65 mph.Im just missing something.I will be greatful for any help.
Old Aug 31, 2010 | 10:09 PM
Franklin2's Avatar
Franklin2
Sounds like fuel starvation. If it does it sooner going up a hill rather than going down, I would look for a fuel filter that is clogged or something like that. Going up hill uses a lot more fuel than going down.
Old Sep 1, 2010 | 07:40 PM
Old Time Ford
I check if there is a differance between hills and flats it does the samething.I put a fuel filter on it just before I had the other problem Im going to get another one and try that.
Old Sep 2, 2010 | 06:17 PM
Old Time Ford
Found the problem
The ignition module is going bad and causing the spark to be poor.
Old Sep 2, 2010 | 08:25 PM
Stangrcr1's Avatar
Stangrcr1
Glad you found it. Only so many possibilities.
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Feb 10, 2014 07:08 PM
Fastbull
Apr 22, 2012 05:44 PM
xtmsports
Sep 10, 2010 06:05 PM
rehorne
18
May 21, 2005 05:31 PM
Tim
Sep 7, 2004 08:35 PM
