I made it
Old May 15, 2007 | 02:04 PM
luvemhot's Avatar
luvemhot
I made it
Well it is on the way
I ordered my DP Tunner today
stock,on start,high idel,60 tow,80 ecno, 100 play
I have a BTS VB in the garage just waitng for me to put the two of them together. need to buy some trany fluid and a filter. and go to work
well I hope that brown truck rembers where my house is.
wish me luck
Keith
Old May 15, 2007 | 02:13 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
LOL good luck Luvemhot, im sure youll like it,
Old May 15, 2007 | 02:16 PM
Izzy351's Avatar
Izzy351
Did you call them or fill out the order form online? I was going to order mine earlier, but I forgot to look at the PCM code. I'll see if I can find an inspection mirror today because I really don't feel like pulling the PCM out...
Joe
Old May 15, 2007 | 02:45 PM
PETE'S_6.0PSD
Joe its 2 min to pull the pcm out, maybe 10 if you going to do it first time,
Old May 15, 2007 | 02:56 PM
Izzy351's Avatar
Izzy351
Okay, Okay.... I'll go do it here in a few. What is it?? Like three 10mm bolts, right?
Old May 15, 2007 | 03:05 PM
ernesteugene's Avatar
ernesteugene
On my early 99, the PCM code is on a sticker on the front inside of the drivers side door jam. It was also on the rear of the PCM on the cover that plugs the access hole where a chip plugs onto the computer circuit board.
Old May 15, 2007 | 03:10 PM
PETE'S_6.0PSD
yeep its 10mm and i think 8mm for the bolts under dash, not sure on the 8 , and look for the sticker when you open you driver door its little white sticker closer to hinges, on mine was allready gone, 3lettersand 3 numbers for PCM and 3 letters and number for auto trans mine was DPC422 and trans PMT2
Old May 15, 2007 | 03:49 PM
Izzy351's Avatar
Izzy351
So there were two codes on the PCM -- DPC-462 & VDH2. Are those the ones I need??
Old May 15, 2007 | 04:40 PM
luvemhot's Avatar
luvemhot
one was the family code and one the pmc code I gave him both it should say next to them, I had to pull mine out
Keith
Old May 15, 2007 | 04:53 PM
PETE'S_6.0PSD
Izzy, this sounds good, call Jody, and ask him, but from the# it sounds good to me,
Old May 15, 2007 | 04:58 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Hey Keith -
are you using the 6637 or the AIS? Just curious...
Old May 15, 2007 | 05:01 PM
MAKO314's Avatar
MAKO314
Jody can get the pcm code from the vin #
Old May 15, 2007 | 06:41 PM
luvemhot's Avatar
luvemhot
papa
I am using the 6637 right now
Keith
Old May 15, 2007 | 06:49 PM
Tenn01PSD350's Avatar
Tenn01PSD350
PMT2 and VDH2 are PCM codes, as is NVK4 and I don't know any others off the top of my head. Mine was a PMT2.
Old May 15, 2007 | 07:00 PM
Uzumati's Avatar
Uzumati
Yep, Hey Izzy your truck has VD________________________________________________ _____h2. LOL
Kieth welcome to the darkside
