Sponsored by: Real Truck
Bump Steer
Old May 14, 2007 | 11:48 PM
Jeeprj's Avatar
Jeeprj
Bump Steer
I have an 06 4x4 F-250 power stroke. When I hit bumps on the hwy I get bump steer in the steering wheel. Kinda feels like the old Fords did many years ago.....scary! It is worse when I have my 30' toy hauler on the back. Is this normal? Is their a fix? Maybe a Heavy duty sway bar? If so where can I find it?
Ant thoughts?
The dealer says everything is normal. Go figure.
Old May 15, 2007 | 09:19 AM
ReAX's Avatar
ReAX
If your at stock height, you do have problems. Bumpsteer is created by tire travel, as the tire moves up, the distance between the spindle pivot and pitman arm is reduced, but the linkage remains at a constant. So the tires loose toe-in. Bump steer is commonly the front of one tire pushing away more than another. Talk to some alignment shops in your area, someone there will know the procedure to reduce it.
Old May 15, 2007 | 01:49 PM
johnnysF350's Avatar
johnnysF350
I'm pretty sure that what your describing is an inherent problem with these trucks. When the 05's came out with the new coil suspension, it was so bad that people started referring to it as the death wobble. I think one of Fords fixes was to put a steering dampener standard on all the SD's. From what I have heard it has helped reduce the problem a great deal, like to the occasional bump steer, but not eliminate it completely. I feel the same thing in my '06 when hitting moderate bumps on the highway. Mine isnt unbearable and I have found that with just a very slight correction and a quick firm grip on the wheel it recovers quickly. Even my old '03 with the leaf spring suspension had some degree of it from day one. I'm sure that the factory dampner isnt the best, so maybe buying a better aftermarket or a dual setup would help out a bit.
Old May 16, 2007 | 11:56 PM
Jeeprj's Avatar
Jeeprj
Thanks for your thoughts guys. I think I will try the streeing dampener first. If that dosent work a good alingnment shop.
Old May 17, 2007 | 12:57 AM
brunetz71's Avatar
brunetz71
The more dampeners (steering stabilizers) you use the better it will be. I changed the OEM dampener on my 05 for a Fabtech and added 2 more Fabtechs straight on the axle. No more bump steer 4 me!!!
Picture: http://new.photos.yahoo.com/brunetz7...04384868907/29
chi6488
6.4L Power Stroke Diesel
Aug 5, 2013 10:26 AM
murph1
2009 - 2014 F150
Mar 15, 2011 08:18 PM
josh1899
2004 - 2008 F150
Jul 18, 2007 12:39 PM
automaticj5
1997 - 2003 F150
Jun 10, 2005 04:52 PM
randallc
Jan 11, 2003 04:35 PM
