Modular V10 (6.8l)
V-10 advice
Old May 14, 2007 | 10:20 PM
Bdox's Avatar
Bdox
V-10 advice
I have a 99 E 350 MH with the V-10, only has 28,000 miles on it.
The thing has been flawless so far and all I have done to it so far are minor services. I really love this motor and I am concerned that I might be overlooking something as far as servicing goes. Like is there anything that needs to be attended to based on the fact that its eight years old, even though the milage is low?
Thanks
Old May 15, 2007 | 12:43 AM
Monsta's Avatar
Monsta
Sit. Stay.
Maybe some of the emission hoses. The PVC hose may be getting old. You can inspect for dry-rotting and such. That's the only thing I can think of as afar as the engine goes.
However, brake fluid absorbs water over time. You may want to consider changing the brake fluid.
Old May 15, 2007 | 01:27 AM
Bdox's Avatar
Bdox
Good thought on the brake fluid, especially since it sits so much.
What about belts?
Old May 15, 2007 | 12:26 PM
Monsta's Avatar
Monsta
Sit. Stay.
Well, there's only one. You can change if it shows signs of aging. Pretty cheap insurance.
Old May 15, 2007 | 12:54 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
PLUGS!!!! PLUGS!!! PLUGS!!!
8 years without removing them? Go buy a Timesert kit BEFORE you start taking them out - you're probably gonna need it.
Just kidding
Mostly...
I'd do all the things you should be doing at 100K miles. Figure like oil changes, 3 months or 3 thousand miles.
So, 8 years, 8*12 months = 96 months, or 96 thousand miles. So it's time for the 100K service.
Fuel filter, definitely, since those get clogged at less than 20K miles. Clean the MAF, check all the hoses, change the belt (if it's not already squeeking), etc. etc.
Old May 15, 2007 | 01:30 PM
Big Orn's Avatar
Big Orn
And boots. Might as well, even though the ones you remove "look" good.
Old May 15, 2007 | 03:52 PM
krewat's Avatar
krewat
Yup! I keep forgetting those things
Old May 15, 2007 | 05:44 PM
Bdox's Avatar
Bdox
All good thoughts. Thanks guys.
Paul_inCT
Nov 16, 2014 08:04 PM
tydel
British Columbia
Dec 1, 2012 06:04 AM
tydel
British Columbia
Apr 16, 2008 09:48 PM
ken04
Modular V10 (6.8l)
Nov 9, 2005 12:28 PM
masseysbronco
1978 - 1996 Big Bronco
Jun 13, 2005 12:15 PM
