Anyone do BG transmission service ?
I,m currently planning to change the fluids on my 2007 F350 CC V10 before winter. It has about 34000 miles on it and has done some plowing.
I started calling around looking for a dealer that does the heated tranny flush. So far no luck . The dealer closest to me (with a good rep) does offer a tranny service with BG additive. Is this worth while or just snake oil? Btw the non heated tranny service is $229.
Thanks
Paul
Thanks
Paul
I believe my manual says to change the ext. filter every 30k. Being only 4k over the recommended interval I sure as heck would not pay 229. The ext filter is about $30 from ford and only takes a 22mm socket to change. There is a drain plug in the trans pan to drain out and replace the fluid but at that low of mileage I wouldn't pay for a flush. The majority of owners ( not members on here). Likely never change the filter let alone the fluid. IMO a flush this soon in the service life of the trans is not needed. But I understand being proactive as well.
There is no way I'd use any type of chemical flush in one of my transmissions.
Changing the fluid at this time is a good idea, but I do not believe in using chemical cleaners. If you can't find a heated flush machine I recommend changing the external filter and changing the 8 or so quarts that will come out of the pan when you drain it. The internal filter never needs to be changed.
Funny reading some of the replys of what to and what not to put in our tranny's. I did the flush and bg additive at 30k and again at 60k. The first was a local shop and when I posted here what they added I got bad replys. At 60k I had it done at the local dealer and guess what they recommended adding? you got it! BG additive. They said you will never have a problem with the correct fluid and this additive and if you do BG will cover $2500 of your bill. So I am running BG additive since 30k and have 78k on her now and pull a trailer and plow snow.
on
Only do flushes with the right oil. Ford would have an additive if it was needed. Everyone is always trying to sell additives for everything because people fall for the hype and it is money in their pocket. It would probably be easier to throw dollars in the toilet than to add useless foreign fluids to a vehicle.
All the additives you will ever need are already in the proper formulation of oil for the specified transmissions.
Thanks for the replies so far..
I was thinking that doing a filter change and fluid drain would be good enough. I just didn't want to skimp and run into "Pay me now or Pay me 3x later!"
I didn't price the part/oil yet! I wasn't too excited when they told $229 for something that isn't much harder than changing engine oil.
Being Proactive.......
When did you you think a flush is appropriate 60K
on
What if Ford recommends BG additive? The 2 dealers I have been to both carry it and recommend it. When transmission service is done on schedule it comes with a warranty. Pretty darn good if you ask me, a company that stands behind their product.
Ford doesn't recommend BG flushes. You are confusing independent businesses, namely the dealers, with Ford Motor Company.
No dealer is owned by Ford and they pretty much can do what they want. If they invested a bunch of money in a BG machine, of course they are going to recommend it. But that doesn't mean Ford recommends it.
on
Do we all do exactly what "ford" recommends?
I'd rather take my chances with a flush and use 1 quart of BG additive mixed into 17gts of fluid that comes with a warranty then change 1/2 of my fluid and filter and call it a day.
