trans problem
Old May 14, 2007 | 09:49 PM
mtnman01's Avatar
mtnman01
trans problem
I have a 1997 f 350 crew cab,diesel the trans slips in reverse only when its been run for a while an hour or so,once it cools down the slipping is not near as bad or wont slip at all,what can this be,oh and by the way I sure am glad that I stumbled upon this site theres tons of info here,and this being my first diesel I can use all the help I can get. thanks in advance for any help
Old May 15, 2007 | 09:17 AM
Cuda_jim's Avatar
Cuda_jim
Welcome to FTE! You already discovered this is the best site on the 'net for your truck.
Get it scanned a tranny shop, most will do it for free. This should pipoint trouble areas to look into 1st.
Sounds like a valve body problem. If you have a lot of miles on the tranny it may be going bad. Especially if you tow/haul heavy. New fluid and filter is a good place to start but it's not likely to cure it.
You can try getting a kit for the valve body, it addresses reverse slippage.
http://www.transmissioncenter.net/e4od.htm
Scroll to the bottom of the page. Part # KE4OD-V
mx21
15
Oct 11, 2014 06:47 PM
gl0116
Jan 19, 2014 04:16 AM
68rs327
Nov 13, 2013 10:59 PM
jmanskippster
Nov 27, 2008 06:52 AM
Dieseladdict
Aug 13, 2006 06:39 PM
