gear ratio?
Old Jan 18, 2014 | 02:58 PM
gl0116's Avatar
gl0116
gear ratio?
I just picked up an 86 f250 diesel out of CA and I was trying to figure out the axle ratio- jacked up the back, marked the driveshaft and tire, spun the driveshaft- 1 turn of the tire = approx 1.75 turn of the driveshaft. How can that be- is there a limited slip involved? Is the rear slipping? Did it with both tires up, 1 down, spun the tire and spun the driveshaft. Got the same results every time- I've never heard of an axle ratio under 2 something- am I being totally stupid? I have driven the truck but not over 35- the trans (C6) is slipping I think but the truck goes ok once it engages.
Old Jan 18, 2014 | 07:50 PM
85e150's Avatar
85e150
Double it. Maybe you have 3.54s. Is there a tag on the diff anywhere?
What is the axle code on the warranty/data plate on the door?
Old Jan 18, 2014 | 09:22 PM
gl0116's Avatar
gl0116
thanks, I didn't realize you have to do that on an open rear, and I don't really understand why. I'm right on on the 1 3/4 turns, so 3.54 works for me.
Old Jan 19, 2014 | 01:30 AM
BruteFord's Avatar
BruteFord
If you are only turning one tire, you need to turn it twice to get the ring gear to turn once because of the differential. Look at it this way, 1 of 2 tires is turning, so it's turning 1/2 as much. When I do this I block one tire and turn the other 20 times, this turns the ring gear 10 times, so 35-1/2 turns of the driveline would be 3.55 gears, best most accurate way to do it.
Old Jan 19, 2014 | 04:16 AM
04fxdwgi's Avatar
04fxdwgi
If it's not a posi, only lift 1 wheel and do the turning and it'll count correctly.
MacsV10
May 21, 2019 12:11 PM
Victor L
Nov 20, 2010 10:58 PM
68Rookie
Kansas Chapter
Jun 19, 2009 05:55 PM
BarnieTrk
Dec 19, 2005 04:24 AM
pipes
May 24, 2001 11:39 AM
