Sponsored by: Real Truck
99 front unit bearings
Old May 13, 2007 | 03:00 PM
jhemr's Avatar
jhemr
I have an early 99 that the unit bearings are going bad.
What is the difference between the early 99 and the later 99 and up unit bearings ?
Can I update mine to the later units ? What all is different or needs cahnged to do this ?
I've tried searching, but can't find the up front answers for my questions.
Thanks in advance.
Old May 13, 2007 | 08:43 PM
high ho silver's Avatar
high ho silver
There are some differences with front end parts for the early 99 ( like U bolt shape) but I believe the hub would be the same for 99-04. I think the only option you have at the parts store would be if you have ABS up front. Those bearings come with the ABS wire attached.
Old May 13, 2007 | 11:03 PM
jhemr's Avatar
jhemr
Mine is a pre 3-22-99, and I remember something about a flange being 11 mm thick on these and 13 mm thick on the 3-22-99 and newer.
Old May 13, 2007 | 11:31 PM
jhemr's Avatar
jhemr
OK, I found what I was looking for... If anyone has anything to add, please do.
https://www.ford-trucks.com/forums/4...el+bearing+hub
stemo76
Jun 4, 2015 09:01 PM
Diamnd1
Feb 19, 2015 08:35 PM
Rattler05.5
Feb 14, 2014 12:33 PM
AIbandit
Jan 16, 2014 11:45 AM
Kajtek1
May 10, 2010 03:12 PM
