2003 Expy with P0405 code
Old May 11, 2007 | 06:25 PM
Bedasi's Avatar
Bedasi
2003 Expy EB 2wd. I got the code "P0405 EGR Sensor A Circuit Low Input" today. Any ideas how to fix it? I know it deals with the EGR, but what all can I do. Where is it?
Thanks for any help!
Old May 23, 2007 | 09:57 PM
Bedasi's Avatar
Bedasi
Step 2
So I took the EGR Valve off and cleaned it, but light is still on. Any ideas what to do next? What else can I clean or replace?
Please help as the light is VERY annoying!
Thanks....
Old May 24, 2007 | 08:04 AM
c_hohensee's Avatar
c_hohensee
I am not sure if that is the fix for that code, but as a rule you have to clear the code and then see if it returns. To do this you either need a scan tool that will clear the codes or disconnect your battery for about 10 min. and see if it returns.
Old May 27, 2007 | 01:39 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
There is a 5v reference going to the DPFE (fancy name for the EGR position sensor). This code is basically stating that the sensor isn't seeing the whole 5 volts. This can be cause by a bad DPFE sensor, open 5v reference wire going to the sensor, or bad computer (highly unlikely).
These DPFE sensors have been redesigned as they caused a lot of problems, so it is your likely culprit. Make sure you get a Motorcraft sensor if you just want to "put one on and see", as a lot of the aftermarket brands still use the old design.
I should warn you though.. don't be surprised if there is another issue somewhere. Usually when these sensors go bad they set a P0401 code... but I still think this is most likely what is bad. Good luck.
wiwillis1980
Mar 22, 2020 07:41 AM
Ebutcher
Dec 8, 2015 07:41 PM
Afreis
Oct 29, 2015 06:50 PM
Dr. Dirt
1997 - 2003 F150
Sep 7, 2014 07:06 PM
weberr7
Jul 2, 2012 03:22 AM
