Wiring ?... Please help
Old May 11, 2007 | 10:16 AM
madcowranch's Avatar
madcowranch
I'm working on a '72 F600 with a 361. The alternator/ regulator/solenoid wiring harness was burnt up and I ordered a new one from Centech (per someone's advice on here).
The new one they sent me didn't account for the 3 wire plug that came off the old harness and went into the firewall (Centech rep says you don't need it). Well, evidently I do because nothing was happening when I turn the key.
So I ran the wires like they used to be and now when I hook up the battery posts, the engine just starts cranking by itself regardless of where the key is turned. I have to unhook the battery just to get it to stop cranking.
Any ideas on what I've done/ need to do?
I'm lost here so any ideas are much appreciated!
Rich
Old May 11, 2007 | 11:12 AM
jdgreen72's Avatar
jdgreen72
if you wanna rigger nig it you can put a push button in the s-terminal circuit between ign switch and solenoid. however i would wanna keep it original. A guy i used to work with had the same prob on like a 69 when he swapped 302 for a 351. we never did figure it out the right way.
Old May 11, 2007 | 11:58 AM
qman's Avatar
qman
Whare this with your Centech rep. Or better yet, talk to a Centech rep that's worth a *****.
Old May 11, 2007 | 02:20 PM
Mil1ion's Avatar
Mil1ion
Sounds to me like you have a charging circuit hot wire running to the wrong spot.
any hot wire from the alternator will run to the charging gauge.
The Ignition switch gets it power thru the main harness from the starter relay battery post.
Can you take a pic and show me what you are referring to ?
There isn't much that can be hooked up wrong on an old ignition switch
Old May 11, 2007 | 02:27 PM
madcowranch
Well I guess I fried my solenoid because now its a closed circuit all the time.
I switched solenoids and everything is working correctly now.
Rich
Old May 11, 2007 | 06:07 PM
Mil1ion's Avatar
Mil1ion
Or...... yes, that will cause it as well
Old May 12, 2007 | 12:57 AM
jdgreen72's Avatar
jdgreen72
sometimes you can't smell the dog shot until you step in it. that was prob this guys prob too.
dobeydude
Jan 29, 2013 08:22 PM
77 ford shortbed
Oct 25, 2008 02:37 PM
bigredtruck
Apr 14, 2006 08:40 PM
79pos
Mar 8, 2005 05:27 AM
Joel Mullis
Nov 1, 1999 07:33 PM
