ufo??
Old May 9, 2007 | 12:49 PM
250turbo's Avatar
250turbo
ufo??
hi guys, have cali model with flying saucer behind fuel pump. is it needed blew mine up in ak.,dealer did not have part,put bolt in its place,got about 10k getting home runs good ,
thanks kurt
Old May 11, 2007 | 11:22 AM
250turbo's Avatar
250turbo
bosch part #9 401 240 169 ,does truck need this part? running about 75psi fuel pressure
thanks
Old May 11, 2007 | 03:39 PM
Cuda_jim's Avatar
Cuda_jim
If you don't have one now and it's running good, IMO you don't need it but I really can't say for sure.
It's just a damper so the fuel system doesn't see all the pressure pulses that are sent by the fuel pump like on a non-cali (Fed truck). The Fed truck fuel pressure is all but impossible to measure. The needle bounces fom 40-90 on my truck. I assume the cali trucks don't have the big swing in fuel pressure.
Old May 13, 2007 | 02:50 PM
250turbo's Avatar
250turbo
cuda jim
thanks for answer, did not think l would hurt anything with both trucks using same fuel pumps . thanks again
KURT
trepid94
Sep 18, 2016 11:48 AM
kevin316
May 27, 2013 11:18 AM
Country Traveler
Jan 12, 2011 01:53 PM
blue88EB
1978 - 1996 Big Bronco
Jul 23, 2007 04:50 PM
