Axle ratio ?
Old May 7, 2007 | 09:19 PM
onepeiceatatime's Avatar
onepeiceatatime
Axle ratio ?
trying to fig out my gears without counting the teeth if i jack it up and turn the tires one tunr of the tire the driveshaft turns 1 1/4 any idea what gears i have the truck has a 4 speed
Old May 8, 2007 | 04:13 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Look on the rear end for a Ford ID tag number. The info is also available on the Rating (VIN) Plate located on door face near latch. See where it says AXLE? Post the numbers here, or use the FTE axle decoder.
Old May 8, 2007 | 05:57 AM
onepeiceatatime
the thirdmember has know ID tag on it was trying to find a eaier way than ****ing the teeth but thany you
Old May 8, 2007 | 05:59 AM
NumberDummy
Did you look at the VIN plate? There is the axle code listed there, too. Post it, and I can decode it. The last three digits on the second line of the VIN plate is the axle code.
Old May 8, 2007 | 03:14 PM
onepeiceatatime
if the truck had the orig rear in it i would do that the third is a 67 or newer 9 in is all i can tell you so i guess the only way to tell would be to count the teeth?
Old May 10, 2007 | 09:53 PM
Grigg's Avatar
Grigg
Sometimes the numbers on the gear are teeth count numbers, and you just divide.
If you are looking at the ring gear just count the teeth on that and the pinion, and divide, this is the most accurate method.
If you want to count turns, turn both wheels at the same time 10 turns, count pinion turns, then divide pinion turns by 10, this will be close.
Or turn one wheel 20, hold the other, and divide pinion turns by 10, close again.
Grigg
Old May 12, 2007 | 10:18 PM
ul37's Avatar
ul37
there is an easier way with out doing any math. lift the wheels of the ground mark one wheel with crayon at 6 o'clock position than mark driveshaft at 6 o'clock. than count drive shaft turns till mark on wheel is back at the 6 o'clock position. example 3 1/2 turns on shaft one turn on wheel 3.50:1 ratio.
joe
Old May 13, 2007 | 08:24 AM
onepeiceatatime
i have did that one but what it came out to was 1 1/4 turns of the drive shaft to one turn of the tire
Old May 13, 2007 | 09:03 AM
Grigg's Avatar
Grigg
Sounds like you lifted one wheel, turned the driveshaft, and got 1.25 turns? If so then the mistake you made is not lifting both wheels, because of the differential and how it works when only one wheel turns it turns twice as fast as two wheels were turning. So, if you git 1.25 turns of a wheel to one driveshaft then multiply by two and you may have 2.5 ratio. This method is fairly inaccurate, and why I listed a better method in my first post.
By using more turns and dividing you have less error.
Try it my way, and let us know what you find.
Grigg
Old May 13, 2007 | 11:06 AM
onepeiceatatime
ok if i did that right cam out with 2;75s the trucks runs down the road at 60 at about 2300 rpm's in 4 gear it has a 223 in it might that sound right ?
Old May 13, 2007 | 01:16 PM
Grigg's Avatar
Grigg
What is your actual tire diameter?
With that info and this site you can get a good guess as to what you have. http://www.drivetraindirect.com/t_gear_calculator.htm
Good luck,
Grigg
Nolo263
Sep 15, 2014 09:24 AM
82airborne82
Sep 29, 2011 09:49 PM
BarnieTrk
Dec 19, 2005 04:24 AM
ford_boy4819
May 19, 2002 03:49 AM
teamwizard
Sep 30, 2001 06:40 PM
