what gear ratio?
Old May 17, 2002 | 08:51 PM
ford_boy4819's Avatar
ford_boy4819
what gear ratio?
can some body please tell me a way to find out what gear ratio i have in my 79 4x4?..the tag is missing off of bot the front and rear..i did the spin the tire and count the turns trick and i came up with 1 3/4 turns of the drive shat to 1 full turn of the tire..is this a reliable way of finding out the ratio?...
Old May 18, 2002 | 09:37 PM
Cope's Avatar
Cope
what gear ratio?
I'd be willing to bet you have 3.54 or 3.55 gears. You must have
an open diff in that rearend. When doing it that way you need to spin the tire twice and count, or just once and double the turns of the driveshaft. In your case that would gives us 3.5, so its probably something like a 3.54 or 3.55. Of course the most accurate way would be to open up the diff and count teeth, divide ring gear teeth by pinion teeth and you got it.
-Cope
95 F-150 4x4
4.9L M5OD
Front Truetrac Rear Detroit
3.73 Precision Gears
Warn Premiums
4" Superlift Superunner
Old May 19, 2002 | 03:49 AM
the law's Avatar
the law
what gear ratio?
'77fordtony
19
Dec 5, 2015 12:51 PM
Davidvc1964
6.4L Power Stroke Diesel
May 22, 2013 10:20 AM
k_conner
Feb 10, 2009 11:00 PM
mudslinging79
Bronco II
Oct 30, 2008 11:07 PM
onepeiceatatime
May 13, 2007 01:16 PM
