engine bogs
Old May 7, 2007 | 08:23 PM
bseinwv's Avatar
bseinwv
Unhappy engine bogs
I Just Recently Bought A 1986 E 150, 5.8 4barrel. Been Setting Several Years, With Very Little Use. (2700 Mi.) Rebuilt The Carb,replaced Fuel Pump,new Fuel Filter, New Plugs, Acc. Pump, Checked Egr, Checked Vac. Advance, All Seems Ok But, It Idles Fine But Wont Take Gas. Totally Dies For About 10 Sec. Then Runs For About 3 Then Dies Again. Impossible To Drive. Anybody Know Whats Causing This?
Old May 7, 2007 | 08:25 PM
Franklin2's Avatar
Franklin2
Turn the engine off, and while looking down the carb throat, push the throttle back. You should see two strong streams of gas pour into the engine. If you don't, there is something wrong the accelerator pump system in the carb. Possibly left a check ball or needle out during the rebuild?
Old May 7, 2007 | 08:44 PM
bseinwv's Avatar
bseinwv
Thanks Dave, You May Be Right, I'll Check Tomorrow And Take The Carb Off And Check Passages If I Dont See Gas.
Old May 7, 2007 | 09:10 PM
Franklin2's Avatar
Franklin2
There is usually a needle under the large phillips head screw(under the squirters in the throat) that is easy to lose.
Old May 8, 2007 | 09:34 AM
bseinwv's Avatar
bseinwv
Dave, I checked fuel when throttle was pumped. Lots of gas!!! Idles perfect, takes gas when setting and idleing, put it in gear and forget it, cant get it to take gas at all.
Old May 8, 2007 | 07:09 PM
gearhead351's Avatar
gearhead351
Could it be possible that the somthing in the tranny is stuck not allowing it to rotate? Or somthing else in the drivetrain? Cause if you can rev it up out of gear and it dies when you put it in gear that might be somthing to look at. Just thinkin out loud here. Is the clutch draggin on the flywheel?
Old May 8, 2007 | 08:05 PM
Franklin2's Avatar
Franklin2
Take the vacuum advance line off and plug it. Now what does it do? If it runs terrible all the time like this, then I think you might need to re-tune the mixture and the idle setting with the vacuum line off. Then find a port on the carb that does not have vacuum at idle, only vacuum when you rev the engine. This is where the vacuum advance needs to be plugged in.
Old May 8, 2007 | 08:57 PM
bseinwv's Avatar
bseinwv
Gearhead351, Auto Trans Ok, Engine Won't Take Gas Off Idle, I Think Its A Carb Problem, So I'm Trying Every Suggestion Dealing With Carb. I May End Up Replacing It.
I'll Try Dave's Adj Tomorrow. Thanks Guys!!
Old May 8, 2007 | 11:38 PM
Piffery1's Avatar
Piffery1
If it's a Holley carb, check for a blown power valve.
Old May 10, 2007 | 08:06 AM
bseinwv's Avatar
bseinwv
Nothing helped, so i took the carb off, took off primary bowl and found an o ring not seated and tore on the brass pump passage tube that goes from the primary metering body to the main body. solved 95% of the problem. $.25 o ring caused me about a weeks worth of frustration. my fault, I put the kit in the carb. (MY FIRST) THANKS FOR THE HELP!!
Boodrow379
Aug 11, 2013 05:11 PM
charlie72924
Nov 4, 2011 03:46 PM
grass valley calif
Sep 22, 2011 08:47 PM
JOSEPHU
Apr 2, 2008 03:35 PM
1955effie
16
Oct 22, 2006 03:38 PM
