beeping from dash area
Old May 7, 2007 | 04:37 PM
1950t's Avatar
1950t
I have an 04 S/D 6.0 with a superchip programmer when driving i hear a beeping noise from under the dash on drivers side when i let off the throttle it goes away anybody else hear of this Thanks
Old May 9, 2007 | 05:21 PM
1950t's Avatar
1950t
Nobody has even heard of it?? Im the only one? Thanks
Old May 9, 2007 | 05:37 PM
Beerstalker's Avatar
Beerstalker
I have never heard of a beeping that only happens under throttle.
There is a beeper that goes off when your keys are in the ignition and the door is open, when your seatbelt isn't fastened, when there is a problem with the airbag system, and when the lights are on with the truck off and door open. Are you sure it isn't one of these? Is the seatbelt light or door ajar light on? Are you sure it doesn't chime a certain number of times and then let off?
Old May 9, 2007 | 05:50 PM
1950t's Avatar
1950t
No its not that kind of beep.there is no repition hard to explain unless you hear it thanks
Old May 16, 2007 | 09:55 AM
CyberRad's Avatar
CyberRad
I think I know what you are talking about. It sort of sounds like a beep. I think it is the turbo. Is your sound constant or every so often? With the sound I am thinking about, I hear it every now and again under accel and cruise.
Old Dec 19, 2010 | 06:35 PM
donf610's Avatar
donf610
I just googled the beeping noise Im hearing and ended up here. Mine sounds like a faint back-up beep you hear on large trucks in reverse. Only does it when Im laying on throttle to increase boost. It just started doing this. I have a stock 04 w/85k miles
Old Dec 19, 2010 | 08:18 PM
teppler's Avatar
teppler
Mine had when I pulled a steep grade with my 15,000lb 5th wheel,what I called an electronic high pitched squeal, after replacing FICM it is much less and barely noticable. I think it is one of the high voltage components in the FICM
Old Dec 19, 2010 | 08:53 PM
miner999r's Avatar
miner999r
The beep of doom!! Do not ask for whom the beeper beeps - it beeps for thee! To abusively paraphrase the beloved bard of London. Sorry couldn't resist - humour problem.
greatone111
2004 - 2008 F150
13
Jan 9, 2020 08:58 PM
bigcountry25
Electrical Systems/Wiring
Oct 4, 2013 06:52 AM
pabear89
Escape & Escape Hybrid
Aug 24, 2011 12:57 PM
Donny_D
Aug 11, 2009 05:45 PM
John7894
Jan 4, 2005 01:33 PM
