Pistons for 393w
Old May 7, 2007 | 12:47 PM
1963f100's Avatar
1963f100
Pistons for 393w
I'm building a 393w and am in need of some pistons with about a 19 or 20cc dish (I think). I need 302 style pistons as I am using the stock 5.956 351w rods. I will be using World Products Windsor Sr. heads with 64cc chambers and would like to have a compression ratio of about 9:1. I would like to use some fairly inexpensive forged pistons if possible. Any suggestions?
Old May 9, 2007 | 03:50 AM
WarWagon's Avatar
WarWagon
I build my 393 with KB pistons. I can find the number if you like. They have one with a 22cc dish. More importantly, though, you need to figure out you Dynamic Compression Ratio based on your mechanical CR and you cam timing. I build mine for a work truck. I had to use 69cc heads and CNC the piston to make it run on 87 with a short duration cam. Do your homework and it should come out fine.
Gibby55
May 24, 2011 03:41 PM
wvroughneck
Jan 3, 2011 02:19 PM
jonbass40
Feb 26, 2010 09:00 PM
kellar
18
Nov 9, 2007 07:40 PM
alk3myst
Aug 13, 2003 10:37 PM
