1978 - 1996 Big Bronco
1993 4EOD/Push button switch on shifter
Old May 6, 2007 | 03:48 PM
RA81222's Avatar
RA81222
The little LED I believe is burned out on this switch.It had been flickering on and off erratically on some occasions when pushed, but now is out completely.The O/D button still working.I was wondering if the switch assy is a dealer item only or maybe Advance Auto or someone may have one?Anyone have the Ford part #?thanks
Old May 6, 2007 | 04:07 PM
fordfaninIL.'s Avatar
fordfaninIL.
I do believe that this is a Ford only part, and you may have to order the whole assembly. I do not know the part #.
Old May 7, 2007 | 06:40 AM
GlennFordx4's Avatar
GlennFordx4
I asked about this before and someone here said that with a micro screwdriver you can pop the cover off were the light is, I haven't tried yet I am waiting to try on a truck at the junk yard first.
Old May 7, 2007 | 03:13 PM
RA81222's Avatar
RA81222
I did pop the cover off.No big deal.I slid the switch assy out with the LED onit.It is a threee prong switch.Funny thin is today I tried the button again and the light came on again and flashed erratically again.It now will not come on again.Is it flashing codes or just going bad?
Old May 7, 2007 | 04:37 PM
dallas lewis's Avatar
dallas lewis
I got a working LED from a junkyard, but I would think that you could buy it at the dealer. I think the design is the same since they started using them(somewhere around 1990) until now. It seems they would have them just laying around, and it seems like they would be cheap as well.
Old May 7, 2007 | 07:15 PM
Hendricksbus's Avatar
Hendricksbus
could be a code check intoo that!!
Old May 8, 2007 | 07:12 AM
muckypaws's Avatar
muckypaws
they are pretty cheap to replace if they are faulty. I have a spare one here if you want it but it might cost more to ship it back to the US than to buy a new one locally.
Simon
Old May 8, 2007 | 02:58 PM
RA81222's Avatar
RA81222
thanks Paws-I will look locally.Joe
Old May 9, 2007 | 02:58 AM
muckypaws's Avatar
muckypaws
I think they cost about $20 from ford so a 3rd party make would cost you 10 bucks from Bronco Graveyard.
http://broncograveyard.com/bronco/i-...on_and_cap.htm
Old May 10, 2007 | 04:36 PM
Kid Bronco's Avatar
Kid Bronco
i have the same prob with mine....it happened one day i went off road...came back and it was like that. I could careless just so it works, but it is werid how it flickers on and off though
Old May 11, 2007 | 03:53 AM
muckypaws's Avatar
muckypaws
when I imported my truck the OD button and light didn't work. After disassembling the steering column cowl I discovered the cable had been severed by the gear shift mechanism. Maybe those of you who are suffering from a flickering light are in the process of developing this condition.
It was simple to solder back together and then pad thoroughly with tape and conduit.
SeaCarr
Jan 25, 2015 12:36 PM
mabc926
Sep 1, 2010 02:47 PM
DeezDay
British Columbia
Nov 18, 2007 10:26 AM
mitchw32
Jan 31, 2005 08:21 PM
mark78truck
May 11, 2003 08:42 PM
