power window problem
Old May 5, 2007 | 06:43 PM
menz300's Avatar
menz300
I have a 93 f250 you can hear the motor run whrn you push the switch and hear the gears going around but the window doesn't move. This came gradually it started out by slipping a little when puttin git up and then just quit after it sliped a couple times.
Old May 5, 2007 | 07:05 PM
Bear1_301's Avatar
Bear1_301
The gear assembly is wore out, you can buy replacement parts or if your mechanically inclined, yoou can take the motor out & jerry rig it with some nylon dolls. I used JB weld to repair mine?
But here's a link that will show you what they are.
http://www.lighthills.com/gear%20kits.htm
johnboggs21
19
May 18, 2010 01:08 AM
Larry85355
Apr 14, 2008 10:49 PM
menz300
New Member Introductions
May 5, 2007 05:29 PM
Dmartin_1
18
Dec 29, 2006 05:56 AM
wesmansr
Electrical Systems/Wiring
Jan 25, 2004 10:36 PM
