overflowing transfer case
Old May 5, 2007 | 05:19 PM
rlit's Avatar
rlit
04 screw with a 5.4 and auto trans poured out 1 + qts of fluid till it stopped ! not running of course ! 84,000 mi on it and no problems ,[ yet ??] any ideas what,s happening ? did'nt seem like I added that much to the tranny .
Old May 5, 2007 | 05:47 PM
Cuda_jim's Avatar
Cuda_jim
Do you mean transmission or transfer case? It's very unlikely the transfer case was pouring fluid. If so, were was it coming from?
Old May 5, 2007 | 05:59 PM
rlit's Avatar
rlit
the transfer case fill bolt , one says drain one says fill took it out and woosh 1 qt + of tranny fluid ! always thought the transfer case was a seperate case , no common seal ? is this new tecknology to save money ?
Old May 6, 2007 | 01:18 PM
rclarke's Avatar
rclarke
There is a 2 way seal in the front of the transfer case to keep the oil separate. If that seal fails the oil will come from the transmission and overfill the transfer case.
Old May 6, 2007 | 03:27 PM
rlit's Avatar
rlit
thanks , I have 15000 left on extended warranty , it says it is covered , I'll contact a dealer tomorrow . first time user , ford nut too , 86 bronco 96 bronco , 04 screw , thx rclarke .
FTE Trigger
North Carolina Chapter
Jan 27, 2007 06:57 PM
Multipierce
1997 - 2003 F150
Oct 12, 2003 03:02 PM
3.8 & 4.2L V6
Jan 23, 2003 10:01 AM
Aug 2, 2002 06:19 PM
oz9609
Feb 27, 2001 07:45 PM
