1978 - 1996 Big Bronco
changing my tranny
Old Feb 26, 2001 | 08:21 PM
429boss's Avatar
429boss
changing my tranny
iwas wondering if i had to remove my transfer case to change the tranny on 85 bronc? any help would be greatly appericated.
Old Feb 28, 2001 | 10:39 PM
Steve_Uzi's Avatar
Steve_Uzi
changing my tranny
Yes you do.... its actually fairly easy.. drain it... remove the drive shafts and linkage.. and drop it... the NP-208's are light when empty...
Uzi... Yamaha Sleds, Honda Bikes, and Ford Trucks....
Old Apr 8, 2001 | 03:29 PM
jjbench's Avatar
jjbench
changing my tranny
I also have to change the tranny of my 89 bronco. I was wondering if it is completely necissary to drain the transer-case before I remove it.
Old Apr 8, 2001 | 06:43 PM
rwjr's Avatar
rwjr
changing my tranny
the t-case draining is to reduce weight...it also makes sense to go ahead and change the oil anyway while you're under there....
Old Apr 8, 2001 | 07:39 PM
billyb's Avatar
billyb
changing my tranny
it is a lot easier to remove the t-case first, then you can more easily handle the tranny. the time spent removing and installing it is less than the time spent trying to balance the assembly while trying to get tranny back on engine with t-case attached. you are less likely to damage the parts and yourself this way.
Old Apr 9, 2001 | 04:05 PM
Bob_VT's Avatar
Bob_VT
changing my tranny
fgadsden75
Nov 15, 2016 06:57 PM
jayram75
Mar 13, 2009 10:47 PM
KAS300
Oil & Lubrication
Feb 22, 2006 05:06 PM
SAUKA
Mar 30, 2004 11:07 PM
d0n_3d
1983 - 2012 Ranger & B-Series
Jan 17, 2004 12:00 AM
