1997 Air Conditioner doesn't work... can I test it?
Old May 4, 2007 | 03:47 AM
460's Avatar
460
1997 XLT 5.0 AWD
The compressor never runs.
I suspect a low charge, but I was wondering if there are any tests I can do to help determine if it may be some other problem before I put it in the shop. Is there only 1 fuse to check for the A/C system? Can I check for voltage somewhere, like the low pressure switch connector to see if the compressor *should* be running... but isn't because of a low charge? Is there anything else I should check?
Old May 4, 2007 | 06:20 AM
steve(ill)'s Avatar
steve(ill)
you can buy a low pressure gauge and hose at Auto Zone... at rest the high and low sides will both have maybe 100 psi of gas inside. when the comprssosr starts, the low side drops to 30 and the hight side goes up to about 250 psi. it you have 100 wihen not running, and the compressor will not start, then you have some elect problem.
Old May 4, 2007 | 08:17 AM
F3Beam's Avatar
F3Beam
My compressor lost its charge over the winter and wouldn't kick in and run either. After charging it now runs okay. Next time I'm just going to get the kit from Wally-World and do it myself.
Old May 4, 2007 | 12:54 PM
460's Avatar
460
Thanks, I'll check it out.
Redwolfbuddy
Jul 1, 2013 12:07 AM
Petik
Jul 22, 2010 03:24 PM
staysbroken
Jun 9, 2010 02:26 PM
GRN250
May 27, 2010 10:10 PM
87-302-jim
Jun 7, 2004 11:54 PM
