Removing rod from ground?
Old May 4, 2007 | 03:41 AM
rebocardo's Avatar
rebocardo
How about cutting it off close to the ground, dig a few inches deep right around it and hit it with a 12 pound sledge hammer. Probably drive it the rest of the way in.
> theres a peice of rebar in my front yard the state left there and i cant pull it up
Well, it is probably a survey marker and it might be illegal to remove. I would leave it, makes having a survey redone MUCH cheaper if it is a marker. You can still drive it into the ground though.
Old May 4, 2007 | 04:28 AM
Torque1st's Avatar
Torque1st
Posting Legend
A smooth ground rod is hard to get a hold on. Rebar is easy. Try wrapping a chain around it. Then just pull it out with a high lift jack. A ground rod usually has a steel core with a copper plate that would make it difficult to weld.
Old May 4, 2007 | 04:33 AM
sierraben's Avatar
sierraben
tdister did say "rebar", and 1/2" (#4) at that.
Me? I'd wrap a chain around it and pull it out with my 81 F150; in compound low.
I love beer.
Old May 4, 2007 | 04:45 AM
Torque1st's Avatar
Torque1st
Posting Legend
I love beer.
Ahh I see that little addition to his post now, lost it in the sig jumble etc, -thanks!
Rebar is easier to hold on to but then if a tree root has grown around it it can make it tough.
If it doesn't pull then cutting it off below ground is easiest.
Old May 4, 2007 | 06:02 AM
wizzard351's Avatar
wizzard351
when we pull the poles out that hold our dock in at moms we use a cherry picker to pull strait up.wrap ya a chain around it 5-10 times making an X pattern put the long end to the picker and jackem out'a there
Old May 4, 2007 | 06:55 AM
modar's Avatar
modar
I had the same problem, What I did was take some pliers and inch it up useing a small block for leverage. Worked great for me, give it a try.
Old May 4, 2007 | 09:45 AM
dono's Avatar
dono
Gone but not forgotten.
I would drill a hole in some scrap plywood (for a base), slip it over the rod, put a jack on it and jack it out.
Old May 4, 2007 | 10:29 AM
GLR's Avatar
GLR
I use a bumper jack, a length of chain, and vise grips to keep the chain from slipping on the rod.
Old May 4, 2007 | 12:25 PM
ddrumman2004's Avatar
ddrumman2004
I agree with cutting it off and pounding the remaining piece farther into the ground.
captain p4
24
May 8, 2008 09:55 AM
PirateFins
16
Aug 17, 2006 07:59 PM
TN-W124 Diesel
Apr 11, 2006 07:46 PM
TallPaul
16
May 20, 2003 09:47 PM
