1978 - 1996 Big Bronco
Ignition problem...!
Old Apr 20, 2001 | 12:00 PM
nixvet's Avatar
nixvet
I have a 1988 Bronco xlt...all power with 351w.
When I turn my key, I get all the dummy lights, but no ignition!
Checked the actuator (o.k.) also checked the ignition switch which is o.k. I im getting power all the way to the firewall of passenger compartment but no power at firewall of engine compartment! What's up? I'm getting tired of starting the engine with a screwdriver at the starter solenoid...
Help...and
Thanx...
nixvet
Old Apr 20, 2001 | 05:10 PM
AlM's Avatar
AlM
Old Apr 21, 2001 | 05:46 PM
iknowitall's Avatar
iknowitall
It is the starter, ford was making crappy starters for a while there is a recall for them I don't know what years but californa is making ford recall all the starters.
Old Apr 21, 2001 | 08:47 PM
nixvet's Avatar
nixvet
Thanks for the tip, iknowitall...!
But:
How do I test the starter to be sure I don't replace it unnecessarily, and...
Why does my motor start fine when I use a screwdriver to jump the starter solenoid?
Thanx in advance...
NixVet
Old Apr 23, 2001 | 12:10 PM
bjw's Avatar
bjw
drive your truck to auto zone and they can check your starter on the truck, and you might want to check the ground cable from battery to the block.
sometimes they get corroded and may cause this good luck,
jaykaran
17
Feb 14, 2011 12:55 PM
cdat81986
Jan 31, 2011 08:24 PM
nixvet2000
Aug 28, 2010 09:06 PM
nixvet2000
23
Jan 31, 2004 04:34 PM
nixvet
Nov 25, 2002 12:47 AM
