Plugged Cat??
Old May 3, 2007 | 09:28 AM
Thomsen's Avatar
Thomsen
Plugged Cat??
I am suspecting that my 94 f-150 may have a plugged catalytic converter. My mileage and power are suffering even after a complete tuneup (new plugs,wires, cap, rotor, and filter). I have a laser temp gun and measured the temperature on the inlet and outlet of both cats. They both had about a 40 degree difference, with the hot end on the inlet. Does this sound like a plugged cat to you guys??
Old May 3, 2007 | 06:59 PM
dkf's Avatar
dkf
If the cat has never been touched there is a good chance its clogged. A pipe or broom handle will unclog it.
Old May 3, 2007 | 11:01 PM
351M's Avatar
351M
A plugged cat will cause overheating, backfireing, if you have a stainless exhaust tip, they can turn gold due to the excess heat, you can also wind up with a fire in the carpet from that. The big thing... After a drive on the highway, they will glow red.
Old May 4, 2007 | 01:15 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
A Carsound's high flow cats will improve your flow.
Drill a hole upstream of the cat, throttle it hard in neutral,
if it's plugged you'll feel the exhaust back pressure.
Worse would be to Mig the hole shut or replace the cat.
The high flow cat flows just detectable vs an empty cat but legal,
passes smog tests with ease provided everything else
is in proper tune.
gman97005
Exhaust Systems
Jun 26, 2013 03:23 PM
05 CO King Ranch
Apr 19, 2007 03:24 PM
mike2112
Exhaust Systems
Aug 8, 2006 08:28 PM
No_BS
Exhaust Systems
Jun 30, 2003 06:04 PM
