Sponsored by: Real Truck
Steering column electrical problems
Old May 3, 2007 | 12:09 AM
LaredoF350's Avatar
LaredoF350
I am having some problems in my column. When I tilt my wheel right up, my headlights will sometimes go out. Previously I had some wire chafing on my tow/haul harness that was blowing a fuse once in a while. Are these common problems?
Old May 3, 2007 | 01:44 PM
Beerstalker's Avatar
Beerstalker
I have heard of wire chafing issues in the steering column on here before, but I wouldn't exactly call them common.
Just wondering though do you put your steering column up and down a lot? Trying to figure out if that may be the cause, or if some trucks just don't get the harness installed very well.
Old May 3, 2007 | 02:16 PM
75F350's Avatar
75F350
My 02 SD had the problem. The turn signals would not work if the wheel was down, I had to drive it wuth the wheel in the up position (like a bus), until I opened the column to find the harness was too tight, and needed to be a little longer. The connector was actually pulling apart with the wheel down. Simple to fix. while i was in there, I just pulled some slack for all of the wires, and it never has happened again.
Old May 3, 2007 | 09:54 PM
msgtg's Avatar
msgtg
Not real common but we've heard of them before.
Like you saw above, you need to play with the harness to get some slack in it.
Sep 26, 2023 02:47 PM
speedemon1084
Feb 16, 2016 09:30 AM
astembridge
21
Jun 17, 2013 10:02 PM
biggkahuna83
Oct 1, 2012 10:57 PM
napass2004
27
Jul 19, 2011 07:07 AM
