6637 mod
Old May 2, 2007 | 01:04 AM
powerstrokin007's Avatar
powerstrokin007
6637 mod
Got my filter today and drilled the hole for the filter reminder, Not sure if they changed the filter design but the end is a bit thicker now. Looking at the pics on guzzle's site, his doesn't look thick at all. Had to open the hole a bit more to get the rubber grommet to sit a bit flush in the hole. Hell if it pops out, I'll get it so the grommet will slide in and put a bit of RTV just to hold it in place.
Old May 2, 2007 | 06:48 AM
mueckster's Avatar
mueckster
Sounds like you got it figured out.
Old May 2, 2007 | 08:07 AM
kennedyford's Avatar
kennedyford
Yes they did change the end thickness by quite a bit. Its just a fight to get the grommet in but otherwise its just as good.
Old May 2, 2007 | 08:47 AM
F250_'s Avatar
F250_
I had the exact issue when I did mine in January, but the filterminder is still holding tight.
airjeff
Oct 6, 2012 03:17 PM
civicmindeddogooder
Nov 9, 2010 07:27 AM
1950ford
Oct 17, 2008 09:37 AM
Randybee1
Nov 7, 2006 06:41 AM
namrehs300
Nov 6, 2005 09:18 AM
