Engine temperature switch
Old May 1, 2007 | 03:56 PM
tbirdrief's Avatar
tbirdrief
Smile Engine temperature switch
Hello,
I just put some mechanical guages in. I have a question on the water temp.
Is there only two sencers for temp?
Which sender is for the temp guage on the dash? I thought i replaced the correct one ( the one on the driver side head). Then I saw the old gauge rise when the new one did. I don't want to disconect the the sender that controles the "cold advance solenoid" or the "low idle solenoid".
Thank you,
Jeff
Old May 1, 2007 | 05:35 PM
KJLYPW's Avatar
KJLYPW
The 112*F switch for the cold advance is on the top front passenger side, just behind the radiator hose outlet. Two on the drivers side, one is a temp indicator and the other is the overheat light I believe, not sure which is what!
Old May 1, 2007 | 06:36 PM
dieself250's Avatar
dieself250
Cold advance swtich has 2 wires on it neer the t stat, sender for dash gauge, drivers side neer water pump below AC compressor it has one wire , Over heat sender is in drivers side cylinder head has one wire
Old May 1, 2007 | 09:46 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Temp senders on drivers side of the engine.
Old May 1, 2007 | 09:47 PM
Dave Sponaugle
Fast idle and timing advance switch, passenger side of the engine.
Old May 1, 2007 | 09:52 PM
tbirdrief's Avatar
tbirdrief
Talking
Thank you very much. That puts my mind to ease.
trackenator
Mar 17, 2011 10:02 AM
borcht warrior
Mar 29, 2009 01:18 PM
hdman6
Sep 6, 2006 06:19 AM
fyre82
1983 - 2012 Ranger & B-Series
Feb 16, 2006 02:09 PM
oldfordtrucksrule
Jan 1, 2004 09:43 PM
