one more guage mod question
Old Sep 5, 2006 | 02:43 PM
hdman6's Avatar
hdman6
Question one more guage mod question
Is there a need for the tranny temp guage in the set of 3 guages on the column ? we have the tranny temp guage in the dash anyway, whats the difference? thanks Jeff
Old Sep 5, 2006 | 03:44 PM
Cuda_jim's Avatar
Cuda_jim
The one in the dash isn't very accurate IMO. Very important to monitor tranny temp if you're doing any HP upgrades.
Old Sep 5, 2006 | 04:00 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
the stock tranny temp gauge shouldnt be there. look at this article to see why.
http://www.itpdiesel.com/store.php?transgauge=1
Old Sep 5, 2006 | 04:12 PM
Pony Power's Avatar
Pony Power
Strokin, that article is right on. This morning I happened to pay attention to my gauges and the dash tranny temp gauge was in the middle of its operating after about 10 minutes and my Auto Meter Gauge hadn't even moved yet.
Old Sep 5, 2006 | 05:25 PM
ryaneverk2's Avatar
ryaneverk2
What I wish the DieselManor site would do there is continue that, and tow a huge trailer up a hill or go forward/reverse to get the tranny up to 210 or so, and compare the 210 to what the stock gauge shows. Even up to 225 where it's time to pullover, and see what the stocker shows, and if it tells you it's time to pull over.
Old Sep 5, 2006 | 09:36 PM
DaveWilliams's Avatar
DaveWilliams
Thumbs up Normal range
I had read somewhere on FTE here, that the gauge reads in the normal range about 100* or something close, and goes up to the scale only when the fluid gets up to 248*. I am not sure what the significance of 248*was, but according to the article, the gauge will NOT move beyond the circle on the normal range till it hits the majic number of 248* and then it goes up to the red....then it's too late...I have a 9500# fiver and going through the mountains when its 100 outside, with my 6.0 tranny cooler, I have NEVER seen over 160*. Whether it's pulling nothing or pulling the fiver through the mountains, the stock gauge stays where it always has....and the ISSPRO gauge flucuates between 150* and 160*. I had heard to expect outside air temp +75 and for 99% of my driving that is accurate but when it got up over 100 outside, I never saw over 160* on the gauge..and always try to keep her below 180 is another good rule of thumb...just my 2cents worth.......Dave
Old Sep 5, 2006 | 09:54 PM
white Buffalo's Avatar
white Buffalo
I'm glad I put the aftermarket tranny guage in also. I normally see tranny temps at 80 degrees above outside air temp driving unloaded around town. When towing my 10,000 lb 5'er I see anywhere from 140 -190 depending on the grade and outside air temps. The stock one just sits at normal after the engine warms up.
Old Sep 5, 2006 | 10:00 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I somehow believe those stock in dash temp gauges and oil press etc are wired from sender to pcm that just basically tells the stock garbage to go to normal range when on. They certainly do not move like aftermarket gauges wired directly to the sending unit. Like an idiot light, the PCM sees an out of tolerance reading and tells the gauge to go out of normal, after the event has occurred. Ooops, too late.
BTW Dave, how's the stacks project coming along? I haven't heard.
Old Sep 6, 2006 | 06:19 AM
DaveWilliams
Smile Still working on them
Getting designs together to get stainless mounts for the stacks. Doctor bills keep getting in the way.....more to follow......Love my ISSPRO gauges though!!
Frozen001
Jan 6, 2009 08:07 AM
bkcowboss
15
Jan 26, 2008 03:00 PM
Mopey
Nov 19, 2004 04:28 PM
restorit
Electrical Systems/Wiring
May 9, 2002 10:32 PM
