Power steering is jerking
Old May 1, 2007 | 03:50 AM
Totally Tuna's Avatar
Totally Tuna
I was checking all the fluids the other day and noticed the Power steering fluid was low. I topped it off. It is stll reading less than full on the dipstick.
Imeadiately after this the steering wheel started kicking back while turning. At speed and in driveway. I read on some sight most likely this one or Diesel Stop that someone was advised to drain the fluid and put in ATF.
What should I do before I replace the power steering pump. I have not driven more than a couple of miles since this problem started.
It is in a '92 F-250 7.3l 4X4.
Old May 1, 2007 | 10:35 AM
Heavy460's Avatar
Heavy460
Might not be steering.Check for bent tie rod or loose Idler Arm/Pitman Arm.
Old May 1, 2007 | 02:20 PM
2jhanna's Avatar
2jhanna
you should be using type f atf anyway.
Old May 1, 2007 | 10:15 PM
speedrdr's Avatar
speedrdr
not sure if this helps but have a similar problem in that mine is hard to turn--but only to right. can't remember who posted a possible problem/solution in that it may be a valve sticking on the p/s pump. haven't figured out where or how to check valve yet. need to get manual out and look at pics. this might be something else for you to check if linkage isn't obvious problem.
speedrdr
tndiesel
Jul 11, 2007 02:17 PM
kntryboy
1997 - 2003 F150
Nov 27, 2005 06:07 PM
RUF150
May 30, 2004 05:45 PM
MJW
Mar 26, 2004 10:17 AM
