motor mount replacement
Old Apr 30, 2007 | 03:50 PM
someday's Avatar
someday
my 89 has a broken motor mount on a 460 2wd c6...it looks impossible to change...what do i have to remove, loosen to get to the bolts and change?
Old Apr 30, 2007 | 08:49 PM
ReAX's Avatar
ReAX
My 79 400 was straight forward, watch the fuel lines and wires as you jack the motor up. Once you get a few inches clearance between motor mount and the purches, put some wood blocks to support the motor while you swap out the mounts on the block.
Old May 1, 2007 | 07:43 AM
someday's Avatar
someday
so if i loosen the trans and two motor mounts she will jack up easily
Old May 1, 2007 | 05:54 PM
ReAX's Avatar
ReAX
Once those are loose, you only have a couple of wires, hoses and gravity on to it.
Old May 1, 2007 | 07:03 PM
someday's Avatar
someday
should i disconnect any wires and/or hoses, maybe even driveshaft?
Old May 3, 2007 | 01:36 PM
someday's Avatar
someday
how long should it take and should i change all of them?
Old May 3, 2007 | 05:47 PM
ReAX's Avatar
ReAX
Figure half a day and there should only be two. Yes replace both while you have it apart.
Only disconnect what you have to. Wiggle and pull lines as you go and if anything feels tight, loosen them.
Austin Climer
Feb 22, 2017 10:17 AM
Funchiemonkey
28
Sep 9, 2015 04:56 AM
Fords_12345
Jun 4, 2005 10:32 PM
Hot Boy
Jan 15, 2003 07:12 AM
donnachie
Nov 24, 2002 06:10 AM
