Motor Mounts
Old Jun 3, 2005 | 08:47 PM
Fords_12345's Avatar
Fords_12345
Motor Mounts
Are the motor mounts on a 66 the same as a 76. What I mean is are the 352 Motor mounts the same on both year trucks or different
Old Jun 4, 2005 | 12:07 AM
Putt's Avatar
Putt
The newer mounts likely have a slightly diff drivers side mounting hole, but it has been said that the hole is there on the earlier frames. They will fit. The drivers side change was to fit the larger power steering gearbox without interference. Any set of mounts from an FE powered pickup will fit.
Old Jun 4, 2005 | 05:28 AM
jowilker's Avatar
jowilker
Uncle Putt is right on the money.
John
Old Jun 4, 2005 | 09:18 PM
Fords_12345
what if the 76 is a 4X4 and the 66 is a 2X4
Old Jun 4, 2005 | 10:22 PM
bertha66's Avatar
bertha66
Should be same.
Old Jun 4, 2005 | 10:32 PM
Putt's Avatar
Putt
The frame horns are the same on all FE powered pickups whether 2 or 4 wheel drive.
Uncle?? My kids aren't that old yet!!!
