Overhead Thermometer Compass Out?
Old Apr 30, 2007 | 08:18 AM
eric777's Avatar
eric777
the overhead therm and compass has went black on me. How do I go about fixing that?
thanks
Old Apr 30, 2007 | 09:45 AM
nlemerise's Avatar
nlemerise
Are you saying that the "miles to empty" and "average miles per gallon" functions are working and the other functions are not OR are all functions out?
Old Apr 30, 2007 | 01:24 PM
eric777's Avatar
eric777
the whole thing is black - no numbers of any kind
Old Apr 30, 2007 | 01:43 PM
tamte65's Avatar
tamte65
Here's thread that tells how to fix it.
Hi, check this thread out:
https://www.ford-trucks.com/forums/4...hlight=console
It tells you how to enter to the console etc, he has all the pics too.
I fixed mine and the problem was: bad solder in 3 of those SMT resistors. Heat up the solder iron (pretty small one!) and in five minutes it is up and running again.
Be carefull when you remove the console, the loose resistors may drop out, you don't want to loose them if you're not a electronic geek
Old Apr 30, 2007 | 01:44 PM
guzzle92's Avatar
guzzle92
It's because of a couple of resistors popping of of the circuit board. Not a difficult repair if you have a small soldering iron (very small for surface mounted devices).
Here is a link on how to repair:
http://www.forgotton.net/diesel/tripcomputerfix/indexframe.html
(edit) 30 seconds too slow....
Old Apr 30, 2007 | 02:15 PM
eric777's Avatar
eric777
it just went out all of a sudden. is it usually these residtors? I dont have a soldering gun, but I know someone who does
Old Apr 30, 2007 | 02:19 PM
guzzle92's Avatar
guzzle92
You should check your fuse to the overhead first, but yea, it just dies.
Old Apr 30, 2007 | 02:29 PM
tamte65's Avatar
tamte65
Yep, and when you open the console you can see why
Supposely some Mexican subcontractor has done those parts?
The PCB soldering is pretty bad quality. Obviously when this is not a safety related component it can be what ever cheapest crap
I'm sometimes working with the automotive (manufacturing) test guys and the testing process there is hard, if it is anything related to safety. They are bullet proof components if they survive those tests. Like our PCM's
I have not heard that, any of our DIY tuners has never actually burned it while scraping the pcb?
Stroking "very" South Texas
F250 -00 PSD 4x4 CC SB with Leer Camper Shell.
Something already done: A/C mod, SS HPX, Cold air intake, Superchip, Excursion sound panels, Lubro Moly injection cleaning.
Soon to be done: DP-tuner, ISSpro gauges, Cackle Cure Kit, Tank Mod, HOT shot oil treatment, Air horns? (is there a legal liability
issue, if somebody gets heart attack )
Old Apr 30, 2007 | 03:31 PM
eric777's Avatar
eric777
thanks guys, which fuse is foe the overhead and is it under the dash or under the hood?
Old Apr 30, 2007 | 03:44 PM
tamte65's Avatar
tamte65
Hi,
The Fuse is Number 19 (10A) inside the cabin. It also gives the power to the overdrive control switch, so if that's working the fuse is OK.
Old Apr 30, 2007 | 04:21 PM
nlemerise's Avatar
nlemerise
Here are the checks to do after the fuse check:
http://h1.ripway.com/nlemerise/Ford/check1.jpg
http://h1.ripway.com/nlemerise/Ford/check2.jpg
77f100jacko
1997 - 2003 F150
Feb 28, 2014 05:34 PM
05F250DSL
Oct 20, 2013 08:17 PM
djdrexler
Aug 1, 2012 02:00 AM
john lucan
Aug 26, 2010 08:03 AM
chefbill
Nov 12, 2001 02:28 PM
