Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Picks
Old Apr 29, 2007 | 06:37 PM
Mr.Ford 351W's Avatar
Mr.Ford 351W
Picks
What brand of picks would you recommend to remove tight cooling system and fuel hoses?
Old Apr 29, 2007 | 07:09 PM
fl1a's Avatar
fl1a
If I were going to get picks for that purpose, I would buy a couple of screwdrivers,
both long shank, of 1/4 and 1/8 inch head, and heat the shank so you could bend
the first inch or less, back to about a reverse 45 degree angle (or tighter). Bend it
so the flat will face the shank, and round off the head a bit so it wouldn't rip up the
hose. A pointed pick tends to tear up the hose, and it is about as easy to use a
knife to remove the hose then. I think I am going to try this myself.
Old Apr 29, 2007 | 08:40 PM
Torque1st's Avatar
Torque1st
Posting Legend
I always just slice the hose off with a utility knife. Old stiff hoses usually aren't worth saving anyway. Just replace them.
When I work on anything I buy new hoses and slime up the inside with silicone dielectric grease, then they come right off.
Old Apr 30, 2007 | 12:15 AM
fixnair's Avatar
fixnair
Several specialty tool manufacturers make just such a tool. Try Lisle, Proto or Mac. I have one that looks like bent screwdriver sharpened to a point. Works great!
Old Apr 30, 2007 | 01:18 AM
Torque1st's Avatar
Torque1st
Posting Legend
Any old worn out or busted phillips screwdriver can be carefully ground to a point and bent with a torch (don't heat the tip). I have one I have used for years like that.
Old May 1, 2007 | 01:20 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
Yes, what Eric said. However, I have 2 Snap On picks just for that purpose. A 6 inch, and a 10 inch, both of them time (and hose) savers.
Old May 3, 2007 | 06:43 PM
Mr.Ford 351W
thanks for the info.
lt56
Oct 3, 2005 05:01 PM
79'f150
73
Jan 17, 2005 03:39 PM
phantom429
Nov 16, 2002 06:05 PM
15sec79
Sep 28, 2001 01:02 PM
shopper
Jun 2, 2000 05:44 PM
