Need an EBPS Support Bracket/Compression fitting/Plate
Replaced my EBPS tube today that runs down the to manifold. Easy. But while I was screwing the EBP sensor back into the support bracket/compression fitting I busted the brass sensor tip off inside the bracket/plate/fitting!! CRAP@#$#%@!!! Tried an easy-out and no go. Wrecked the fitting and made a real mess out of the whole thing.
Anyone have a parts junker out there with that bracket/plate still on it that I could buy from you???
Or, suggestions on where to get one?
Turned what looked like an easy fairly inexpensive repair job into a major expensive mess. Have already ordered a new sensor.
Thanks!!!
