Instrument Panel Removal
Old Apr 27, 2007 | 10:08 AM
rad1026's Avatar
rad1026
I need to remove the Instrument panel to install a switch. My manuel says:
Instrument Panel —Cluster Finish Panel
<meta content="Instrument Panel —Cluster Finish Panel" name="tps_proctitle"> Removal
  1. Remove the audio unit. For additional information, refer to Section 415-01 .
  1. Remove the instrument panel cluster finish panel.
    1. Loosen the screws.
    • Disconnect the headlamp switch, panel dimmer switch, (if equipped) 4x4 switch, passenger air bag deactivation switch, power point, (if equipped) the parking aid switch electrical connectors.
It shows two screws up behind the radio. Is that it? You don't even need to pull the switch handles off first? They all come off with the panel. Is it held in by any clips or anything? Just pull it straight out. It would sure suck to crack the thing. Give me some tips guys. Thanks!
Old Apr 27, 2007 | 02:31 PM
Cuda_jim's Avatar
Cuda_jim
Check this out. It's for anew truck but ford has been installing radios like this for as long as I can remember.
https://www.ford-trucks.com/forums/6...ml#post4666422
Old Apr 27, 2007 | 03:21 PM
rad1026's Avatar
rad1026
yep, I have the DVD Jim. I don't think I'll have a problem with it, just wondering from someone who has taken it panel off if the screws behind the radio are the only one's to remove and if the panel just snaps off. Thanks!
Old Apr 28, 2007 | 05:52 AM
Cuda_jim's Avatar
Cuda_jim
rad1026, Yep it snaps off. Sorry for my confusion. I need to think as fast as I can read. That ain't so fast either.
93nighthawk
Aerostar
39
Sep 23, 2015 08:55 PM
nastyss
Feb 1, 2013 03:51 PM
asavage
Aerostar
May 7, 2012 03:27 PM
T0DD
Sep 14, 2004 05:35 AM
Trampus
1978 - 1996 Big Bronco
Nov 15, 2003 11:04 PM
