3.73's
Old Apr 27, 2007 | 01:47 AM
Industrial_dude's Avatar
Industrial_dude
Thumbs down 3.73's
How many of you dislike your 3.73's and wish you had a 4.10 instead? I know i do! My mileage sucks and so does the power with even stock wheels n tires. I couldnt imagine putting bigger tires and leaving the gears stock. I want to put 4.10's with front and rear lockers. I use ARB air lockers (fr/r) on my excursion and have worked really well with my 40" tires and the tourqe from the diesel. What lockers are you guys using? also just curious whats the biggest size tire I could put on a stock 4x4? although a lift might be on its way, need to find out my options.
thanks
Old Apr 27, 2007 | 08:19 AM
CMOS's Avatar
CMOS
I've got a 3.0L with 4.10 gears, running P235's. VERY glad I have those 4.10's. I have plenty of power with this set-up. My truck is no slouch as-is.
I hear a lot of guys dog the 3.0L, but most of them seemt to have 3.73 or 3.52 gears, so I can understand their position. I plan to move up to BFG 255's after I eat a little more tread from my 235's.
The 4.10 gears, IMO, should be a minimum gearing for anything with a V6.
Good luck.
CMOS
Old Apr 27, 2007 | 08:48 AM
fflintstone's Avatar
fflintstone
The 3.73's aren't that bad a gear, but of course you'd know that the front gets the same treatment if you go 4.10. As far as the mileage goes, she's not even close to break in yet. She should improve. Wendell Borror's ride has 4.0 with 4.10 gears and I beleive he wrote that his got poorer mileage till he got something like 10k on her. He's getting around 22/24 with a couple of simple mods and synthetic lubes. That 4.0 is an excellent engine and one fella was real happy with his new 4.0/4.10 truck.
Stick around and search the threads. You'll learn all kinds about that truck and what you can do with her.
Good luck and congrats
Fred
Old Apr 27, 2007 | 11:22 AM
BuffmanLT1's Avatar
BuffmanLT1
I can't see how you guys complain The 3.45s I have in my truck do just fine, even with the 27" Tall All Terrians. Then again with the 5spd, I have a 1st gear start ratio of like 12.84. Plenty and get up and go for the little truck. 4.10s with the way I can drive would prolly be worthless in 1st gear.
Old Apr 27, 2007 | 01:30 PM
seadoo's Avatar
seadoo
I wish I had 3.73's, all my 94 Splash extended cab has is a 3.08 in it, even with the 5 spd and 4.0 it's slow. But I do tend to get decent mileage on the highway with it. Although towing and hills don't tend to mix to well with it.
Old Apr 27, 2007 | 03:59 PM
racsan's Avatar
racsan
3.73's are about the ideal ratio with stock tires, go with bigger tires and yes lower gearing would help.with to low a ratio it will pull anything but will reallly use the fuel and not have any top end, to high a ratio and you have no power, its hard on the clutch and you also get poor fuel economy because the motor is lugging. keep the motor rpms in the right spot of the powerband will give you the best results. all in all if you are unhappy with 3.73's you may as well skip 4.10's and go up to 4.56 gearing. the 3.0 makes its power higher in the rpm band than the other ford small chassis truck engines and should probly have 4.10's stock. ive found driving with a vaccum gage real imformative, i can maintain a steady reading more at 45 than 55. really shows what wind resistance does.
Old Apr 27, 2007 | 04:19 PM
CMOS's Avatar
CMOS
At what RPM range does the 3.0 hit its best performance?
CMOS
Old Apr 29, 2007 | 06:31 AM
JeremyJ's Avatar
JeremyJ
how hard is it to put different gears in our trucks....i have a 1994 3.0 supercab 4x4 stick shift xl, 166,000 miles
Old Apr 29, 2007 | 01:07 PM
Tiggie's Avatar
Tiggie
I have 3.73's. I drive all interstate. I do not want 4.10's anymore. Something about crusing at 3K all day doesn't appeal to me. You 4X4 guys need them with taller tires.
CMOS, the 2004 3.0 peaks at 154hp @ 5200rpm and 180lb-ft @ 3900rpm.
JeremyJ, you have the 7.5 rear axle. http://www.corral.net/tech/drivetrain/gears.html tells you how to install a ring and pinion into an 8.8, the 7.5 is similar.
Old Apr 29, 2007 | 02:37 PM
Waves's Avatar
Waves
I've regearded my last two that had 3.73's to 4.10's, my present one came with 4.10's and looks like I am gonna go 4.88's here soon -
Michel153
Oct 20, 2014 06:55 PM
Grodyman
Dec 2, 2011 08:09 PM
racsan
20
Oct 13, 2007 05:56 AM
mizzitch
Dec 9, 2004 10:53 AM
Jokenring
Dec 30, 2003 04:12 PM
