Sponsored by: Real Truck
A Good Locker?
Old Dec 29, 2003 | 10:07 PM
Jokenring's Avatar
Jokenring
Thumbs up A Good Locker?
I have an 02 F250 with a limited slip 10.5" stuffed with 4.10s. My question; is the Detroit Soft Locker a good locker for this setup, or does someone know of a better one? With the exception of an ARB or an e-locker.
Old Dec 29, 2003 | 10:15 PM
99f350sd's Avatar
99f350sd
its the best
Old Dec 29, 2003 | 10:19 PM
Jokenring's Avatar
Jokenring
Would it be a straight swap out, or would there be other 'hidden' purchases to be made.
Old Dec 29, 2003 | 10:50 PM
CJack's Avatar
CJack
Detroit locker...a spool with none of the talent or charisma.
Old Dec 30, 2003 | 12:01 AM
abendx's Avatar
abendx
nothing better than a detroit!
mine has worked flawless and i have no complaints.
hidden costs? hummmm, i doubt it. when mine was installed, it cost no extra in parts or labor from the gear swap (well, the cost of the locker was extra).
Old Dec 30, 2003 | 02:48 PM
99f350sd's Avatar
99f350sd
We should do a special on lockers???? Yes its a swap but don't try it yourself unless your a good mechanic with lots of exp. We might be able to run you through it..
Old Dec 30, 2003 | 02:56 PM
Jokenring's Avatar
Jokenring
It shouldn't be that bad should it? I have run through a '73 F250 a few times including an engine rebuild. (The diffs haven't changed that much have they?) The only thing that hasn't had any work done to it would be the NP205 but that's a different story.
Any insight and tips would be appreciated though.
Old Dec 30, 2003 | 02:59 PM
99f350sd's Avatar
99f350sd
just ask away b4 you start.....the bearings and presses do you have access to a good press.
Old Dec 30, 2003 | 04:12 PM
Jokenring's Avatar
Jokenring
Nothing like a good brass drift and a hammer!
FordMuddin'
Aug 7, 2010 09:08 PM
Brown Falcon
22
Jul 12, 2009 08:01 PM
V10man
Offroad & 4x4
Nov 28, 2007 08:51 PM
HRW
Offroad & 4x4
Apr 30, 2003 12:15 AM
