stock turbo
Old May 1, 2007 | 07:08 PM
  #31
97_power$troke's Avatar
97_power$troke
I have my exhaust gauge in the down pipe what is the temp were it will hurt the truck
Old May 1, 2007 | 07:20 PM
  #32
tjbeggs's Avatar
tjbeggs
post turbo temps should not exceed about 900-950, pre turbo max is 1250. short burst over that are ok but no extended runs there. Extended is described as nothing more than to the end of the 1/4 mile, 300 feet when pulling a sled or to the top of the hill when a duracrap or cummins is behind you.
Old May 1, 2007 | 07:26 PM
  #33
plowhand's Avatar
plowhand
Playing in the Dirt
tj, most of the post turbo gauges that I have seen redline at 1050.
Old May 1, 2007 | 07:37 PM
  #34
97_power$troke
mine averages 800 when just driving and 1000-1100 when pulling. is that OK
Old May 1, 2007 | 08:00 PM
  #35
tjbeggs's Avatar
tjbeggs
its somewhat of a mystery as to what the max post turbo temps should be. isspro should ahve a good handle on it so 1050 should be ok. I prefer pre turbo as it is a more accurate picture of the temp the pistons are seeing as that is what I am protecting with my pyro. but its also a more difficult install so it all depends on what you have. I would go with what Plowhand said!
Old May 2, 2007 | 06:41 AM
  #36
97_power$troke
if I do all the stuff that I want too my truck like Injectors & turbo can I still pull with it. I pull a 28' race car trailer & a 5th wheel so will it still pull with out getting real HOT.
Old May 2, 2007 | 08:11 AM
  #37
powrstrkr's Avatar
powrstrkr
Originally Posted by tjbeggs
Extended is described as... or to the top of the hill when a "duracrap" or cummins is behind you.
TJ... Don't you mean Dungamax? LMAO!!
I've hit 1050 - 1100 post turbo a few times but only briefly w/out any problems. I'm flowing so good now it won't go over 900 any more with 16,000 GCWR. But I'm still running stock squirters.
Old May 2, 2007 | 11:21 AM
  #38
97_power$troke
10-4 the egde EZ box has 2 settings 60 hp & 90 hp what should I set it on. I have it on high now and the evolution on high and it set the chcek egine light on but cut the truck on and off and it will reset it.
Old May 2, 2007 | 11:54 AM
  #39
tjbeggs's Avatar
tjbeggs
you should be able to do those tows but you may need to turn your chip to a tow setting or even stock depending on the temps. but then you could always do an intercooler to help too. I was only in my IC setup for $250 by the time it was said and done.
Old May 2, 2007 | 03:44 PM
  #40
powerstroked162's Avatar
powerstroked162
I have seen as much as 1350* post turbinator....... this might be why the stock unit failed.
Cowboy Steve
Old May 2, 2007 | 03:48 PM
  #41
ForemanES's Avatar
ForemanES
I have seen 1600+ pre turbo. I am begining to wonder if there are any more blades on the exhaust side.
Old May 2, 2007 | 03:54 PM
  #42
powerstroked162
thats about 1300 post turbinator. Same ballpark for sure. lol, Those turbine fins start to look pretty brittle after you run hot temps through it and put some eyes on 'em. Mine held up, but the shaft didnt. I think yours are probably shot and you need to upgrade to that BDP D66 big dawg unit
Cowboy Steve
Old May 2, 2007 | 03:59 PM
  #43
ForemanES's Avatar
ForemanES
Ya me too, we need to start a "get me a new d66 turbo fund"
Come on everyone pitch in
Old May 2, 2007 | 04:01 PM
  #44
powerstroked162
I got some change.... any bit helps right? lol
Cowboy Steve
Old May 2, 2007 | 04:03 PM
  #45
ForemanES's Avatar
ForemanES
Yep only $1199.50 more to go come on guys we are almost there
