stock turbo
Old Apr 28, 2007 | 05:14 PM
ForemanES's Avatar
ForemanES
gts motorsports and banks have pipes and y-intakes but are pricey. You can modify some 7.3 pipes fairly easily if you can weld.
(click here) this one comes with the pipes. but you have to modify them to fit.
Old Apr 28, 2007 | 05:38 PM
tjbeggs's Avatar
tjbeggs
My intercooler install has just finished day 2 of 3 and I must say its not a bad job but it is a bit more intense than I thought it would be! Also to modify the pipes I had an extra 7.3 drivers side pipe and a 6.0 pipe (not sure what side) those two pipes cut up and welded back together are what my passenger side is made of. the drivers side pipe is just the 7.3 superduty drives side pipe upside down (Superdtuy cooler end at the turbo end on my truck) with about 8 inch added to the trubo end of it. I will have pics to post when I am done. I will finish tomorrow afternoon after church.
Old Apr 28, 2007 | 09:19 PM
97_power$troke's Avatar
97_power$troke
let me know when you get the pics. 22 hours left on my intercooler on ebay. on the shimmed FPR and the BB do I need to do this if I run the chips
Old Apr 29, 2007 | 03:02 AM
power stroken's Avatar
power stroken
im running an ats incooler on my 95 seems to work well, as was already said with the smaller trubo housing it moves the boost lower in the rpm's. It's alittle nicer for towing with a stock truck(as far as i've found) but it seemed to run out of steam around 2500 ish rpm, so I would run through the gears fast but then lagged on the highway.
Old Apr 29, 2007 | 12:53 PM
powerstroked162's Avatar
powerstroked162
97_power$troke- You dont have to shim the FPR to run a chip. This mod just raises fuel pressure to help reduce lope at idle. I like this mod because I know have more then enough fuel pressure stored up for them big squirtters.
Cowboy Steve
Old Apr 29, 2007 | 05:17 PM
97_power$troke
10-4 sound good, Keep the info. coming THANKS
Old Apr 30, 2007 | 06:23 AM
97_power$troke
what does the Edge EZ box that wires in under the hood do. what does it trun up timming or fuel or what. would it hurt the truck to put a TS 140 chip & the EZ box and the evolution all on the truck at the same time.
Old Apr 30, 2007 | 02:43 PM
ForemanES's Avatar
ForemanES
The edge ez is a $300 10k mod. You can only run the chip and the ez or the programmer and the ez but not all three at the same time.
Old Apr 30, 2007 | 05:37 PM
97_power$troke
I got the EZ box on a trade so it is the 10K mod. it would be good to put it on the truck as one of my many mods on come.
Old Apr 30, 2007 | 05:55 PM
ForemanES's Avatar
ForemanES
Heck ya use it if you already have it. It is stackable with a chip or programmer.
Old Apr 30, 2007 | 07:58 PM
97_power$troke
hell yeah, just put it on and took it down the road does better. in Tjbeggs pics is it the boost line in the y-pipe if so does it read boost better there http://rides.webshots.com/photo/2934...GF?vhost=rides
Old Apr 30, 2007 | 08:53 PM
tjbeggs's Avatar
tjbeggs
no it should read the same no matter where you have it. it was just put there cause thats where the previous owner had it, then with my IC install it still fit (banks y-pipe has a fitting there for it)
Old Apr 30, 2007 | 10:28 PM
  #28
97_power$troke
were do most people put the boost gauge at to get a good reading I think mine is in the map.
Old Apr 30, 2007 | 10:36 PM
  #29
ForemanES's Avatar
ForemanES
I have mine "T"ed into the map sensor line. Flutters a little at 33psi but not enough for me to move it.
Old May 1, 2007 | 06:30 AM
  #30
97_power$troke
that is were mine is I did not know if it would read more were his is at.
