Can you find any casting numbers on the block or on the cylinder heads?
After '64 they started using a metal tag to ID an engine. But these tags are easily lost. If it was built after 1970, Ford stamped the VIN number on the left rear side of the block just below the cylinder head. From 1960-81, the 5th digit of the VIN designates the engine code. Is this the number that you found?
I don't think so. my mechanic is in the process of tearing down the motor now so we will hopefully find some more numbers soon. thanks alot for your time JPW
