Narrowing 9 inch
Old Apr 25, 2007 | 05:14 PM
Witty73's Avatar
Witty73
Narrowing 9 inch
Ok guys, I need some help.
Does anybody have any idea what vehicle, or which rear end the axles come out of that can be narrowed properly? The axles out of my 74 F100 are slightly narrower right after the splines for about 5 inches, and then get beefier. I want to narrow the rearend, and the guy at the machine shop said I have to have the right axles, without the taper, otherwise he cant re-spline them. Any thoughts? Or am I doomed for a set of aftermarket axles?
Thanks
Old Apr 25, 2007 | 05:26 PM
Don Senkow's Avatar
Don Senkow
Strange S/St axles are priced so that resplining axles isn't worth the effort. I'm sure Moser's pricing is much the same. They will be stronger and a lot less hassle. Don
Old Apr 25, 2007 | 10:17 PM
Witty73's Avatar
Witty73
I will check it out, but from what I have seen so far, a pair of aftermarkets run 600 or so, and I can get these cut down and resplined by a reputable shop for 200.
Thanks for the Input
Old Apr 26, 2007 | 06:48 PM
hd4ever's Avatar
hd4ever
Hi
You will have to check it out and see if the axels I have will work. I am thinking these are good specimens. 5 bolt on a <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com[img] /><st1:Street w:st=[/img]<st1:address w:st="on">5.5 Bolt Circle</st1:address></st1:Street> and ½ inch studs. Both axels are 33.187 long from outside axel flange to end of axel. 1.312 diameter by 31 splines. If you want to get further details email me at gostride2@hotmail.com
Old Apr 28, 2007 | 05:31 AM
RTM's Avatar
RTM
If you're narrowing an axle for an application that has HP then you should step up and buy after market axles. Replining the old axles will cause you to lose the case hardening of the factory splines. It will only be a matter of time before the repline axle splines start to twist, if beaten on or used for heavy hauling.
Old Apr 29, 2007 | 12:46 AM
WarWagon's Avatar
WarWagon
If Im not mistaken, I think you can get a set of SS axles for about 299
Old Apr 30, 2007 | 03:28 PM
Witty73's Avatar
Witty73
Yes, I have looked into it further and have decided to go with Mosier axles. Should be money well spent. Thanks for your input.
bob_351
Feb 25, 2011 11:22 PM
Perschml
Dec 16, 2010 06:26 PM
pipman76
Sep 7, 2009 10:23 PM
BR549az
Oct 28, 2006 09:41 PM
Quadrophenia_00
Aug 19, 2005 06:38 PM
