Sponsored by: Kumho
Real Quick Labor Cost Question
Old Apr 25, 2007 | 03:51 PM
smurray's Avatar
smurray
Okay...I'm looking into getting about a 4" lift kit installed for my truck. It's an '89 F-150 4x4 short box. How much (ballpark) can I guestimate for labor costs so I know I'm not getting jipped? I figured about $1000. Thanks.
Old Apr 25, 2007 | 06:58 PM
ReAX's Avatar
ReAX
Most of the shops in our area figure 8hrs for a lift kit. Depending on your rate, I'd suspect an easy $400-700.
Old Apr 25, 2007 | 07:10 PM
smurray's Avatar
smurray
Thanks. I couldn't help it....I'm getting a lift for my truck. Getting 15x10 Mickey Thompson Classic Lock Rims, Cooper STT's, 6" Pro Comp Lift, dual steering stabilizers. I think it's going to look really good...and I think, besides a paint job, this should pretty much complete my old truck. Hell, I've rebuilt everything else on it. They priced it out at $3500 for everything.
Old Apr 25, 2007 | 07:15 PM
smurray's Avatar
smurray
Oh one more quick question...I've got 3.55 gears in my rear diff (only reason I know that is because I just installed a Detroit TruTrac in it)....will 3.55's turn 35" tires without a problem? I've got a pretty new but mostly stock 302 with an RV cam, T-19 4-speed transmission...hopefully it won't have much of a problem. I hate working on gears...they're a pain in the ****.
Old Apr 25, 2007 | 07:48 PM
ReAX's Avatar
ReAX
My 3.55 were too low on my 4speed with 31's, but as long as you don't have overdrive the 3.55s should be close with 35's. For performance though, you may want to look at 4.10s. I loved my 36s with 4.10, but it wasn't bad with 3.55s.
Old Apr 30, 2007 | 10:31 AM
bocephus_3349's Avatar
bocephus_3349
No the 3:55's will no work. The thing i try to tell people over and over again is if your going to be putting on bigger tires you need to change the gears. if you have a automatic with OD then i would go 4;56's if your running the np 435 4spd then go 4.10's because of lack of OD. I have a 93 f-150 6ich and 35's with 5spd i run 4:56's with detroit. That set up woke my 302 right out of a slumber. With the 3:55's you might think you could get better mpg but that is not so true because your having to work it harder to get the same as stock resaults. I get about 12mpg around town 16 on the open road. another thing is save the 1k labor and do it yourself and use the money to do new gears. Lifts are easy and if you havnt done it then make it a learning time. I can complete one now after several installs in about 4hrs with a friend 8hrs by myself. just my .02
Old Apr 30, 2007 | 11:43 AM
smurray's Avatar
smurray
Thanks...I would do it on my own but I'm away in flight school for the Army right now, in Alabama, and I left my truck at home in Montana. I figured if I didn't do it now I never would, which is why I had it done. Also, from what I've been told, since I'm putting on all new radius arms they have to cut the old ones off at the rivets (which is right by where the fuel pump is on the frame). I didn't figure it would be wise for a guy like me to be using a cutting torch near fuel lines, so the professional job felt worth it to me at this point. As far as the gears go, I'm planning on putting an eaton e-locker in the front differential as soon as I get home, and I can re-gear the rear end at the same time as well. Thanks for your info. I'll definately take a long look at installing those 4:56's, although the truck feels really low geared to me already. It's got that 4 speed Borg Warner with the granny gear. At 65 mph in 4th gear I was turning at about 3300 RPM with my old stock sized tires.
Old Apr 30, 2007 | 12:18 PM
bocephus_3349
you will notice a huge difference when you drive it. i have a 66 f-100 as well with same set up 3:55's and np 435 same as t-18 but lower first. you will have to start out in granny from now on unless you can come to rolling stop. you will prob be about 1200 rpm at 65 now. have fun with it and from the bottom of my heart I would like to thank you for your dedication to this great land, and for fighting for my families freedoms. There are plenty of us praying every night for the many men and women like you.
thank you
Mark
Deano52
Projects
Nov 25, 2016 11:42 AM
az28
Modular V8 (4.6L, 5.4L)
Jul 31, 2016 09:05 PM
nojoke327
Dec 23, 2015 07:36 AM
Codyaye
Oct 4, 2015 10:57 PM
powerstrokecowgirl
6.4L Power Stroke Diesel
Jul 28, 2015 02:47 PM
