Glow Plug/Injector Harness Tester
Old Apr 25, 2007 | 12:49 PM
nodakford's Avatar
nodakford
Smile Glow Plug/Injector Harness Tester
I wanted to get a test harness for testing the glow plugs and injectors like the Ford manual lists. The cheapest I found was $80 on Ebay. I really did not want to pay that, so I went to Ford to just buy the connector to make my own. Ford didn'y hve anything so I called International and that guy did not have a clue. Then last week I stumbled upon this website, http://www.source-products.com/public_html/index.html that specializes in Ford harness connectors. Sure enough they had the connector. The only bad thing was that they do not do online order. When I gave them a call to order one, they were the nicest people to deal with. I got my connector the today with the pigtails already attached. So for less then $30 buck I got the glow plug/injector harness tester.
Old Apr 25, 2007 | 01:21 PM
fbilly420's Avatar
fbilly420
thanks for the info that is good to know i think i will call and get one too. nice to have one in the tool box.
Old Apr 25, 2007 | 02:23 PM
DieselCamper01's Avatar
DieselCamper01
Thanks for the info. I believe I will be ordering one also
Old Apr 25, 2007 | 02:58 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Good find there, and thanks for sharing. Alan can add this to his site too if not already there. Props awarded.
Old Apr 25, 2007 | 03:15 PM
F250_'s Avatar
F250_
Great info. Thanks for sharing. Since I'm not fluent with this issue from a diagnosis standpoint, can you share the part number and details about how you use this thing?
Old Apr 25, 2007 | 03:29 PM
Tenn01PSD350
Well, I'm primarily interested for the potential for constructing a break out box. It appears they sell the harness plug for the UVC connector. I'm not sure how he plans to use that for a GP check as I would simply ohm the existing one but I'm thinking BOB. It's bookmarked for contacting them when I do that along with boost leak detector along with..........
Old Apr 25, 2007 | 10:33 PM
nodakford's Avatar
nodakford
A breakout box is in the works, but for the time being since I don't have the most stable hands hold the multimeter lead to glowplug pins I can clip on a test lead to the pigtail.
Fireman350
Apr 20, 2016 02:34 PM
foxracer800
Oct 5, 2007 09:40 PM
KrAzYKARL
4 Cylinder Engines
13
Oct 8, 2006 11:16 PM
Brad4321
Sep 10, 2006 04:09 PM
justasammy
Apr 6, 2005 09:17 AM
