Aerostar Ford Aerostar
Aerostar offroad project
Old Apr 24, 2007 | 08:18 PM
Alabama Rebel's Avatar
Alabama Rebel
I got a 89 Aerostar in the driveway, and was wondering what i should do with it. Im thinking somehow that i can make it offroad. It would be fun to do and i get tired of washing my new truck so i figured this would be the best thing to do. I was thinking Big mud tires, mabey a lift and a huge winch. Can you even get a lift? I dont think ou can unless you get it costom. I have even thought about cutting the back to out and making it look like a truck. oviously i have no clue what im going to do with it so i came to yall. Any thought or ideas would be great.
Old Apr 24, 2007 | 11:58 PM
xlt4wd90's Avatar
xlt4wd90
The Aerostar chassis is not all that strong, so it probably won't stand up to the harsh pounding of off-road travel. Similarly, its bumpers really aren't strong enough to support a winch. The custom work you will have to do will include reinforcement of the chassis, as well as custom fabbing any kind of suspension lift. Then you need to deal with the powertrain...
Why not just keep it a utility vehicle? It's great at carrying people or stuff.
Old Apr 25, 2007 | 12:42 AM
Pablo-UA's Avatar
Pablo-UA
Goog Idea! Your project is the 3rd. 1st is done by my friend, the second is in progress (RuleBracker's project). XLT4WD90 is right. Aero needs some body modification. But it is not so difficult if you have welding machine, cutter and a lot of enthusiasm.
Old Apr 25, 2007 | 08:31 AM
VanGo's Avatar
VanGo
People are putting 4WD chassis under anything and everything these days. I would add $$$ in addition to what Pablo says.
Good luck
Old Apr 25, 2007 | 11:24 AM
bertha66's Avatar
bertha66
I seen a Aero in Portland Or once that had a F250 4wd under the body, it had Alaska Plates on. It looked used and tuff, but it was a long way from home.
Old Apr 25, 2007 | 12:39 PM
Pablo-UA's Avatar
Pablo-UA
Finally I learn what T-case my friend installed to his AWD project - from Toyota, becouse front prop.shaft is on pass. side on his aero.
Old Apr 25, 2007 | 12:55 PM
96_4wdr's Avatar
96_4wdr
the easiest tough 4 wdr Aero conversion would be to drop an Aero body on a rollover late model 4L OHC 4wdr Ranger frame that has been custom extended
Toyota 4wdr V6 PU frame from rollover would work also and much more reliable engine/tranny
Old Apr 25, 2007 | 01:01 PM
Pablo-UA's Avatar
Pablo-UA
There is no Toyota frame under his aero. He has his body enforsed with metal bars, Mercedes engine, mercedes tranny, toyta T-case (manually controlled), UAZ wide axes.
Old Apr 25, 2007 | 01:14 PM
96_4wdr's Avatar
96_4wdr
love those new Yoda 4L DOHC V6's....one tough mother rock climber and logging road racer
Old Apr 25, 2007 | 04:14 PM
Alabama Rebel
what if i cut off the body and make kind of a dune buggy? If i did that would i have to move he engine to the back or what?
Old Apr 25, 2007 | 04:27 PM
Alabama Rebel
always wanted a dune buggy lol. Might just weld a frame together and use the engine
Old Apr 26, 2007 | 12:35 AM
Pablo-UA's Avatar
Pablo-UA
What a reason to move engine back? A lot of work.
Last winter there was a big box with sand and shovel inside. For better weight bistribution....
Old Apr 26, 2007 | 08:47 PM
Alabama Rebel
idk thats what i was asking because i dont want to spend a year on this. All of the dune buggys that i have seen have the engine in the back. The only think is i dont have sand dunes in alabama, just woods and mud, I think they call it a offroad buggy or smg like that. It was just a thought tho, still open for any suggestions
asavage
Aerostar
Jun 17, 2021 01:59 PM
Dogcatman34
Aerostar
Mar 28, 2017 04:47 PM
Aero-fan
Aerostar
107
Nov 30, 2009 03:05 AM
95XLT
Aerostar
13
Feb 2, 2006 08:41 AM
BigMattXXL
27
Oct 15, 2003 11:56 AM
