Aerostar Ford Aerostar
Aerostar offroad project
Old 04-24-2007, 08:18 PM
Alabama Rebel's Avatar
Alabama Rebel
Alabama Rebel is offline
I got a 89 Aerostar in the driveway, and was wondering what i should do with it. Im thinking somehow that i can make it offroad. It would be fun to do and i get tired of washing my new truck so i figured this would be the best thing to do. I was thinking Big mud tires, mabey a lift and a huge winch. Can you even get a lift? I dont think ou can unless you get it costom. I have even thought about cutting the back to out and making it look like a truck. oviously i have no clue what im going to do with it so i came to yall. Any thought or ideas would be great.
Old 04-24-2007, 11:58 PM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is online now
The Aerostar chassis is not all that strong, so it probably won't stand up to the harsh pounding of off-road travel. Similarly, its bumpers really aren't strong enough to support a winch. The custom work you will have to do will include reinforcement of the chassis, as well as custom fabbing any kind of suspension lift. Then you need to deal with the powertrain...
Why not just keep it a utility vehicle? It's great at carrying people or stuff.
Old 04-25-2007, 12:42 AM
Pablo-UA's Avatar
Pablo-UA
Pablo-UA is offline
Goog Idea! Your project is the 3rd. 1st is done by my friend, the second is in progress (RuleBracker's project). XLT4WD90 is right. Aero needs some body modification. But it is not so difficult if you have welding machine, cutter and a lot of enthusiasm.
Old 04-25-2007, 08:31 AM
VanGo's Avatar
VanGo
VanGo is offline
People are putting 4WD chassis under anything and everything these days. I would add $$$ in addition to what Pablo says.
Good luck
Old 04-25-2007, 11:24 AM
bertha66's Avatar
bertha66
bertha66 is offline
I seen a Aero in Portland Or once that had a F250 4wd under the body, it had Alaska Plates on. It looked used and tuff, but it was a long way from home.
Old 04-25-2007, 12:39 PM
Pablo-UA's Avatar
Pablo-UA
Pablo-UA is offline
Finally I learn what T-case my friend installed to his AWD project - from Toyota, becouse front prop.shaft is on pass. side on his aero.
Old 04-25-2007, 12:55 PM
96_4wdr's Avatar
96_4wdr
96_4wdr is offline
the easiest tough 4 wdr Aero conversion would be to drop an Aero body on a rollover late model 4L OHC 4wdr Ranger frame that has been custom extended
Toyota 4wdr V6 PU frame from rollover would work also and much more reliable engine/tranny
Old 04-25-2007, 01:01 PM
Pablo-UA's Avatar
Pablo-UA
Pablo-UA is offline
There is no Toyota frame under his aero. He has his body enforsed with metal bars, Mercedes engine, mercedes tranny, toyta T-case (manually controlled), UAZ wide axes.
Old 04-25-2007, 01:14 PM
96_4wdr's Avatar
96_4wdr
96_4wdr is offline
love those new Yoda 4L DOHC V6's....one tough mother rock climber and logging road racer
Old 04-25-2007, 04:14 PM
Alabama Rebel
what if i cut off the body and make kind of a dune buggy? If i did that would i have to move he engine to the back or what?
Old 04-25-2007, 04:27 PM
Alabama Rebel
always wanted a dune buggy lol. Might just weld a frame together and use the engine
Old 04-26-2007, 12:35 AM
Pablo-UA's Avatar
Pablo-UA
Pablo-UA is offline
What a reason to move engine back? A lot of work.
Last winter there was a big box with sand and shovel inside. For better weight bistribution....
Old 04-26-2007, 08:47 PM
Alabama Rebel
idk thats what i was asking because i dont want to spend a year on this. All of the dune buggys that i have seen have the engine in the back. The only think is i dont have sand dunes in alabama, just woods and mud, I think they call it a offroad buggy or smg like that. It was just a thought tho, still open for any suggestions
asavage
Aerostar
06-17-2021 01:59 PM
Dogcatman34
Aerostar
03-28-2017 04:47 PM
Aero-fan
Aerostar
107
11-30-2009 03:05 AM
95XLT
Aerostar
13
02-02-2006 08:41 AM
BigMattXXL
27
10-15-2003 11:56 AM
Quick Reply: Aerostar offroad project
