Axle identification.
Old Apr 24, 2007 | 07:53 AM
IowaTower's Avatar
IowaTower
My F350 doesn't have a code on the aluminum door tag for the rear axle, my F250 doesn't have an aluminum door tag (doesn't even have doors... or a cab) and niether of my F150s have codes for the front axles (I know they're D44s, but additional info would be nice). All '79s.
I do know the GAWR for the 350.
Is there a code on the axles themselves I can look for? Or another way to identify them?
Old Apr 24, 2007 | 08:21 AM
Ronzukin's Avatar
Ronzukin
Should be a tag on the third member, might be hard to find at first. My third was covered in undercoating for some reason, making it hard to find the tag.
Old Apr 24, 2007 | 03:57 PM
Jermafenser's Avatar
Jermafenser
To the right of the carrier housing, clean the whole area. There you should find the BOM and codes. If you live in the rust belt, cleaning the rust flakes may wear them off.
Old Apr 24, 2007 | 04:04 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Sometimes those codes on VIN plates are stamped away from where they belong...the trans code is a single digit, the axle code is three digits...sometimes they all run together.
Old Apr 24, 2007 | 05:12 PM
Mil1ion's Avatar
Mil1ion
An F350 with Dana 44's ?
IMO, The rear should be a Dana 70 and the front a Dana 60
Need a Bill Of Material number.
shown here.
http://www.lightruck.com/axle_parts_rings.asp
Old Apr 24, 2007 | 05:20 PM
rowdy78's Avatar
rowdy78
axle numbers
hey, if you can find them, they are small, maybe and 1/8 of an inch usually starting with the number 6 and about 6 numbers long, give them to me and i can tell you exactly what it is and what it came out of origianally
Old Apr 24, 2007 | 05:46 PM
NumberDummy
Rear Axle Cover Bolt Holes
Dana 44 = 10
Dana 60/70 = 9
Old Apr 24, 2007 | 06:15 PM
Mil1ion's Avatar
Mil1ion
Dana 44 Bill of Material Numbers.
Old Apr 24, 2007 | 07:17 PM
Mil1ion's Avatar
Mil1ion
More Dana 44 Front axle Specifications.,
Looking close you will see the Axle Weight specs so to match the GVWR of truck model used in.
Old Apr 24, 2007 | 08:55 PM
IowaTower's Avatar
IowaTower
OK. Thanks.
I was unclear; the 350 is 2WD, the rest are all 4wd.
Old May 7, 2007 | 11:34 PM
ashleydaniel20's Avatar
ashleydaniel20
Can you tell me about the tag on an axle I might buy 4.09 D6TA BD- 603763-1. I know 4.09 gears looks like a 44 but from what year?
Old May 8, 2007 | 12:23 AM
Mil1ion's Avatar
Mil1ion
well it looks like from 1976.
I'll check my books
Old May 8, 2007 | 04:05 AM
NumberDummy
Front Axle
D6TA-BD = Dana 44-6HDF / 4.09-1 / 3500lb Axle Capacity / 1976
rogerranger2122
1983 - 2012 Ranger & B-Series
Oct 9, 2016 04:49 PM
JackErnie
Dec 23, 2014 02:46 PM
Fomoco1546
Apr 20, 2014 02:08 PM
jyblood
Feb 16, 2014 03:25 PM
baileybilt
Jul 17, 2008 04:58 AM
