the axle code on the door jam of my 86 F150 2x4 is 163. can anyone decode it? it doesnt match any of the codes i have seen. thanks jim
Your trucks AXLE code decodes to two different things.
The first two digits are the rear axle code: 16 = 3.50-1 / non Limited Slip / 3750 lb. Rear Axle Capacity
The third digit in this case decodes to this: 3 = Power Steering Delete.
The axle codes third digit translated:
2 = 1980/89: Limited Slip Front Differential / 3 = 1983/89: Power Steering Delete / 4 = 1983/89: Power Brake Delete / 5 = 1983: Power Brakes.
Info source: Pages 39 & 41 from the General Information Section of the 1980/89 Ford Light Truck Parts Catalog.
