Door jamb axle code
Old Apr 20, 2014 | 08:25 AM
Fomoco1546's Avatar
Fomoco1546
Door jamb axle code
I have a 95 f-350 and would like to know what axle I have in this truck. Both axle tags are missing, but door jamb axle code reads 26.
Old Apr 20, 2014 | 08:46 AM
Conanski's Avatar
Conanski
The truck will have a Ford 10.25 full floating rear axle under it which will probably have at least a 5300lb rating, but I don't see 26 in the chart.. could it be a 36?
Ford Axle Code Chart | Ford Trucks
P.S. The 2x axle codes are usually associated with 1/2 ton trucks so it's possible the cab has been swapped on this one, have you tried to decode the VIN?
Old Apr 20, 2014 | 08:49 AM
subford's Avatar
subford
Better look again, there was no 26 in 1994 or 1995.
Old Apr 20, 2014 | 09:09 AM
Fomoco1546's Avatar
Fomoco1546
Sorry guys, axle code is 65 not 26. must be too early in the morning.
Old Apr 20, 2014 | 09:28 AM
subford's Avatar
subford
65 = 8250 Cap., 4.10:1 Ratio
Old Apr 20, 2014 | 10:23 AM
Fomoco1546's Avatar
Fomoco1546
So would that make it a ford 10.25 full floating rear? And would it be an open rear not LS? Should I be using 80w- 90w gear oil? thanks
Old Apr 20, 2014 | 12:11 PM
subford's Avatar
subford
Code says it is not a LS rear end.
Old Apr 20, 2014 | 02:08 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
thanks
yes.
open.
yes or preferably 75w 140 synthetic.
Truck Guy99
Jul 29, 2014 06:48 AM
roadrash63
Oct 11, 2009 01:13 PM
ctrain22
Oct 31, 2007 02:15 AM
